Sponsored by: CARiD
Will these fit? Pulling the trigger on 20's (2014 E550 4matic)
Old May 20, 2022 | 03:27 PM
Butta's Avatar
2014 E550 4 MATIC Sedan
2014 E550 4matic sedan (white)
Currently running stock AMG 245/40/r18 in the front and the back on lowering links.
I'd like to upgrade to these Niche Verona M168's. Specs:
Front:
Wheel Diameter: 20 in.
Wheel Width: 9 in.
Bolt Pattern: 5 x 112
Offset: +38 mm
Center Bore: 66.56
Wheel Load (in lbs): 1900
Wheel Color: Black
Wheel Finish: Gloss
Wheel Material: Aluminum
TPMS Compatible: Yes
Back:
Wheel Width: 10 in.
Offset: +40 mm
Center Bore: 66.56
Wheel Color: Black
Wheel Finish: Gloss
As for tires I'm planning on getting 255/30/r20 in the front and 275/30/r20 in the back?
Please advise.
Pic of the rim.
