Sponsored by: CARiD
Rattle on startup 2013 E350 4matic 178 k miles
Old Jul 17, 2022 | 04:45 AM
S-Prihadi's Avatar
Originally Posted by mercyfan
I still can not decide should i replace all 4 selenoid considering my car mileage 180 k miles
Are you speaking of oil control solenoid or the VVT phasor itself ?
VVT Phasor
Oil control solenoid
This is camshaft adjuster magnet, I forgot the actual EPC name, is the one "pushing" the oil control solenoid to flow oil so that the VVT phasor can change timing by oil pressure management
Old Jul 17, 2022 | 05:07 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
leaky electricals 4 x [ solenoid + sensors ]
It's a real good idea while you're around there to change the 4 solenoids + 4 position sensors. This will complete your tune up by replacing weak parts.
They go bad like clock work and send engine oil into the harness by capillarity.
This triple timing chain design is amazing
Old Jul 17, 2022 | 09:09 AM
mercyfan's Avatar
Mercedes 2013 E350 4matic, 2013 ML350 RWD
I mean Mercedes Camshaft Solenoid Kit - Genuine Mercedes 2761560790 | FCP Euro and the price all four including seal and bolt not that crazy like camshaft adjuster OEM 276 050 5100 (last or 4th revision) 4 of them US 3k maybe just bought used engine take that 4 VVT. All 276 050 3600 (3rd revision) made in Europe all out of stock and this is indicated it sell like candy because many MB impacted even in low mileage start at 50k miles.
I also considering below
Mercedes Camshaft Position Sensor - Genuine Mercedes 2769051000 | FCP Euro it only around $50 OEM.
Old Jul 17, 2022 | 09:12 AM
S-Prihadi's Avatar
I see. those camshaft adjuster magnet likes to leak oil into its cable and into ecu. I already replaced mine, all 4, just in case only. 7 years old when replaced but only <30,000KM.
I use latest P/N ( revision probably )
My camshaft position sensors not replaced as it is still the current P/N.
Old Jul 17, 2022 | 12:21 PM
mercyfan's Avatar
I ordered cheap one from aliexpress around $162 ETA Aug 13th
2760503600 2410041 New Intake Camshaft Adjuster Left For Mercedes Benz W205 C205 Coupe X218 A207 S212 C217 R231 Convertible| | - AliExpress
But now I think maybe I should get OEM but the price jump quite step:
Genuine Mercedes-Benz Engine Timing Camshaft Sprocket 2760505100 | eBay $754 the last revision (4th)
Or go to 3rd revision reman OEM
Search SiteSearch 2760503600 - 276050360080 - REMAN CAMSHAFT ADJUSTER (ecstuning.com) $391
Should I cancel and order 3rd revision reman 176050360080 for $391?
Or buy complete set VVT made by Uro Part made in germany for $662
Mercedes-Benz E350 4Matic Sedan 212.088 3.5L V6 Camshaft Adjuster Kit (rmeuropean.com)
Old Jul 17, 2022 | 04:02 PM
Parts sourcing question...
All the combinations are valid choices with Pros & Cons. This choice is like financial investments: it depend what is your tolerance for risks...
The MB genuine VVT is make of soft steel that's easily scratched. This was shown in a video where the Canadian guy filled in the wear carved by the pin with weld. He then showed how the weld steel is many folds harder than stock.
I'd select the genuine China quality without the pretty OEM box markups. By the time you need to go back in the engine to work on the next set of VVT, you can inspect existings and pick a remanufactured kit of newer generation parts.
When you receive your parts do a basic Quality-Control, perhaps move the old VVT spring over to replacement unit to closely match the force necessary to actuate.
Old Jul 17, 2022 | 09:54 PM
  #32
mercyfan's Avatar
You right the last revision OEM around $750 is didn't make sense even 3rd revision around $400 also bit too much. So now my choice between part from China or not OEM but made in Germany between these two:
1. Uro Part made in germany for $662
2. A2760503600 A2760503700 New Left And Right Intake Camshaft Adjuster Set For Benz A205 C205 S205 CLS Shooting Brake E 400 4 matic| | - AliExpress $317
Exhaust Camshaft Adjuster Set Left And Right For Benz AMG C 43 4 matic CLS 400 CLS Shooting Brake E 320 2760501800 2760503900| | - AliExpress $317
It almost same price around $630 for all four VVT.
Should I choose Ura Part made in Germany instead of the made in China?
Old Jul 17, 2022 | 11:18 PM
  #33
German grade...
Prices so close, German does sound better than genuine China, right ?
Old Jul 18, 2022 | 01:44 AM
  #34
mercyfan's Avatar
Yes I would prefer german product than China if price almost the same.
Old Jun 17, 2023 | 03:46 PM
  #35
GLKwanter's Avatar
Rental
You get the adjuster in yet? How did ordering the cheap one work out? I'm in the same boat right now..
Old Jun 17, 2023 | 05:17 PM
  #36
mercyfan's Avatar
I am back to mobil one from I forgot exact name moly oil and it didn't rattle often. so I didn't change yet
Old Jun 17, 2023 | 05:57 PM
  #37
GLKwanter's Avatar
Rental
Oh that's very interesting, once I learn the root cause of this problem, lack of oil at startup, I was wondered if perhaps a specific oil could have an effect on the ever so common startup rattle in the m276 and m278 engines.
I've read about every thread I can find concerning the issue, and every comment on every video, and I have yet to read anyone say what you just said.
Could you please share for all those with this horrible issue exactly what oil brand and weight you're using that stopped the startup rattle? I'm not sure what Moly oil is either, please advise.
And you're sure it was the common startup rattle from the camshaft adjuster like you bought? Guess you can't be sure if you didn't tear it apart, and I wouldn't either if the oil solve the problem. Did Yu ever take off the cover rotate the engine and see it skip to identify which one you need? I haven't with mine but I think I can hear its driver side and everyone says the intake goes first I believe.
You know that one will fit though? I'm curious about how Mercedes updates their parts and changes the numbers and such. Sure would save a lot of money to be able to put in the one you bought.
Thank you
Old Jan 30, 2024 | 01:45 PM
  #38
pfsantos's Avatar
2013 E350 4-Matic, 2008 B200 (sold), 1998 E200K, 1983 200
So reviving this thread as I'm on the same road doing research.
How do you know the Uro is actually made in Germany and not just a German brand or China made and put into a box in Germany?
Maybe I just missed it? We have to be so careful these days!
Paul
Old Jan 31, 2024 | 08:39 AM
  #39
JettaRed's Avatar
Veteran: Army
From what I can determine, URO Parts are made in the US. A.P.A. Industries out of Simi Valley, California manufactures and distributes their URO Parts product line. FCP Euro carries URO parts for some items, which is a litmus test I will use when questioning the quality of a product. In this case, FCP does not carry the URO brand camshaft adjusters. However, ECS Tuning and RMeuropean do. When contemplating parts from well-known European car parts sites, I would go with a US-based company over AliExpress for critical components.
Old Jan 31, 2024 | 09:10 AM
  #40
pfsantos's Avatar
I did a little more digging on URO. While the headquarters are in the U.S., the parts are made worldwide. But it definitely helps that at least there's some oversight in the U.S. I don't have an issue with parts made in some parts of the world, but the quality of materials and construction (basically, QC) has to be there and the company has to stand behind the product. I've had OE and OEM parts and M-B boxed parts with all kinds of countries of manufacture. In the case of M-B, a lot of them from Eastern Europe. Maybe that's why M-B isn't what they were back in the 90's and earlier.
I've used URO parts before, just not for such crucial items as timing system components. I like the fact that FCP Euro carries them, and also Rockauto (although they carry economy, regular and premium brands so you have to pick wisely).
Last place I usually check is Ebay.de when everyone else is expensive. Have found some good deals on name brand parts, even after shipping costs. Had a manual transmission B-Class and some parts were hard to find, especially since it wasn't sold in the U.S. (officially).
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
