Sponsored by: CARiD
W212 NTG 4.0 command questions
Old Jul 7, 2022 | 09:27 PM
Noureddinee's Avatar
E class w212
Hey guys , so my car has ntg 4.0 command system, but i have no audio option , and also when i try the hidden menu i get different one , is my unit very outdated? If so can i update it ? ( I don’t think if i can get the update from the dealer ship here in my country) , or can i replace the whole unit with a ngt 4.5 ?
before all this i was thinking to get the android touch screen but now that I don’t even have the audio option I don’t think it will work if so can i replace my unit with a ngt 4.5 then get the android touch screen
sorry for my bad english
Old Jul 7, 2022 | 11:20 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
what do you mean, no audio option? you don't have a radio or CD player, and your COMAND won't bluetooth link to a phone to stream music off the phone? I'm not familiar wtih NTG 4.0 but I would hope it does all these things.
Old Jul 7, 2022 | 11:27 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
good luck...
It's not immediately clear what issue you're trying to solve.
To upgrade the stock screen over to an Android display you'll need a working Comand host to drive the new peripheral.
Consider reading the Android threads to learn what experience and limitations are like.
Old Jul 8, 2022 | 12:20 PM
E class w212
i have a cd player and radio , but I can’t link my phone with the command to stream music i can only do phone calls
This is the normal screen of my unit as you can see very standard and I don’t have the audio option
And this is the hidden menu
Old Jul 8, 2022 | 12:22 PM
E class w212
please see my reply above
Old Jul 8, 2022 | 02:03 PM
extension...
You have a working Comand 4.0 that offers no BT audio streaming...
I think your best upgrade path is through a compatible Android extension of your choice.
Cheap alternative #1: buy a $10 BT dongle connected on "AUX Input" if your 4.0 provides AUX Input!?
Cheap alternative #2: buy a unit that will rebroadcast your audio over to an FM Frequency in Stereo. I used to have one of these plugged in 12V-Cig. socket with 3.5Jack audio input... there may be BT Input model that will rebroadcast over to FM. Very convenient and simple.
I don't think coding a newer Comand unit is a viable option... unless your research on this topic shows otherwise given unlimited resources.
