Found a couple of weird objects while changing the pollen filter ??
TV motion blocker
This is a great item to replace... it saves the blower "ballast resistor" from burning its thermal fuse.
w212 MosFet speed controller
That's how I learned to change it every once a while
It is by MANN, called FreciousPlus.
When buying a RHD version becareful where you shop, commonly available is LHD one. It is not the same.
FP 29 005/1 << the 1 means RHD
https://catalog.mann-filter.com/EU/eng/catalog/MANN-FILTER%20Katalog%20Europa/Vehicles/CARS%20%2B%20TRANSPORTERS/MERCEDES-BENZ/C-Klasse%20(W204~C204~S204)/C%20200%20CDI%20BlueEFFICIENCY%20OM%20651.913%20(T 00000000238121)/Cabin%20Air%20Filter/FP%2029%20005~1https://catalog.mann-filter.com/EU/e...00000000240495)
FP29005 only means LHD cars.
The yellow side is the super fine element, hence it can not be installed wrong side or raw air side. It has to be on the filtered air side.
Raw air is the white color side.
I do not know if it can be flipped wrong and still install-able or not .... I could never get RHD version one.
AAAAAAH!!!! That would explain why it was such a massive pain in the **** to install the one i bought from Rock Auto Cabin Filter it must have been for a LHD...well that sucks why make 2 different ones???
This is the unit I bought from the States... Multi Layer thats probably now in backwards!!!
You can buy the correct one off eBay but its not cheap! RHD MANN Filter
For normal filter, no problem because both sides of the filter paper has the same "resolution".
That yellow side is super fine resolution for super small bad stuff to be caught.
Dang AU$75.00, shipping and tax will make it AU$150 minimum, landed Jakarta.
