Sponsored by: CARiD
W212 e300 clunking sound
Old Aug 15, 2022 | 10:18 AM
Wawan's Avatar
W212 e300 4 matic
Hey did anyone experienced the same issue?so I have a 2014 w212 e300 4 matic with 130000km on it. that problem I have is, when I am driving and come to a stop or when I back and push the breaks, I get a clunking sound from the rear.help would be much appreciated
Old Aug 16, 2022 | 09:31 PM
Rex Chan's Avatar
2014 E200 sedan
Not much info, maybe CV joint? Or suspension mounts gone. Did you buy recently? Did you hit a pothole?
Old Aug 16, 2022 | 09:33 PM
Wawan's Avatar
W212 e300 4 matic
Ya I did hit a pothole, really bad pop a tire. I did change the cv axels already
Old Aug 16, 2022 | 09:47 PM
Rex Chan's Avatar
2014 E200 sedan
TBH, just take to your local mechanic and have them take a look. I'm sure it will be obvious
Old Aug 19, 2022 | 09:05 AM
benidB's Avatar
W212
Lift Your car with a jack and check your rear subframe and arms. Push and pull all the arms to see if they move or not.
I recently had a similar issue, the part of the subframe to which an arm is connected literally broke off, and the arm was just staying suspended in the air, moving freely, hitting some parts when braking, hence the clunking noise.
the rear subframe corrosion seems to be a somewhat typical problem in this model and the c class..
Let just hope it won’t be this problem
https://mbworld.org/forums/e-class-w212/804679-corrosion.html
https://mbworld.org/forums/c-class-w204/800894-rusted-rear-sub-frame-2013-c-class-luxury.html
