Problem with key
I have a w212 2010 220 CDI and lately, the key has started giving me problems. When the engine is hot, the key does not work. The key cannot turn on the instrument cluster, or crank and engine.
I emphasize that the key opens and closes the doors normally, but it cannot start the car. After 10-15 minutes that the car cools down, the key works and the car starts. 1 week ago, I changed the EIS module but the problem remains.
I assume you haven't tried using the second key fob?
For the price of the EIS module, I suspect you could have bought 2-3 OBD2 diagnostic tools, that could actually tell you why the car will not start when hot.
I don't have another key. A month ago, I went to a service center and after diagnostics, he told me that the EIS module had to be changed because it has a limited number of ignitions.
The problem is that when I place the key, I don't hear the sound of the steering wheel unlocking and when I turn the key to turn it on, no light appears in the instrument cluster. When this happens, I have to wait for the car to cool down and then start the engine.
As for the obd2 scanner, which variant would be more suitable?
In fact, I have a OBD2 but it is only for the VAG group and I am not very informed about the scanners for Mercedes since got the w212 5 months ago.
Thank you,
Mario
This sounds like a bad SAM relay... poke around to swap similar cubes.
