Sponsored by: CARiD
TPMS valves
Old Sep 6, 2022 | 07:54 PM
Benz-LH44's Avatar
E Class
TPMS valves
How would I be able to check my TPMS are in full working order without paying a fortune? Only reason I ask is sometimes it flags up sensor missing but other days it’s totally fine.
also can I buy any compatible sensor or is it recommended to use genuine Mercedes’ ones?
Old Sep 7, 2022 | 02:59 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
TPMS 😆
The TPMS Schrader system can be temperamental to work well in these cars... You need to figure what's going on!
If all pressures go nuts its the CAN-bus module,
if only a single wheel is funny, then its a sensor.
How old are your units?
They rely on a 3V coin battery to broadcast data over to receiver exposed over the rear axle.
Where do you buy your tires?
Good tire place sale "compatible" sensors that should work once registered.
Old Sep 7, 2022 | 03:47 AM
Benz-LH44's Avatar
E Class
it’s usually just the one. Drivers side front. I’ll get it checked out/recalibrated.
the units are probably from 2015 unless changed by previous owners.
I haven’t changed my front tyres since buying this car.
thanks for the guidance. First time writing on a forum lol
Old Sep 7, 2022 | 11:56 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
THERE IS NOTING YOU CAN ADJUST ON MB TPMS.
The alarm pressure is set on ECU, or whatever computer takes care about it INSIDE the car, when sensor location is determinate by directional antennas.
Even $50 scanners do have TPMS reading options. Get 1 .
Old Sep 7, 2022 | 12:22 PM
ONE or ALL ??
Your current issue is limited to a single old sensor furthest away from receiver module.
Are you going to replace 1, 2 or 4 wheel sensors?
Old Sep 7, 2022 | 01:56 PM
kajtek1's Avatar
Receiver distance doesn't matter. The car is having 2 directional antennas, who's placement differs form MY to MY.
Old Sep 7, 2022 | 02:13 PM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
Talking
Maybe someone used the tire sensing a lot, like the front left was leaking for a while and the sensor triggered frequently? mine in my '12 are still original, my '13 also. but it sounds like the battery is going dead. personally I would use OEM, I also thought you could "calibrate" them on the dash while the tire pressures are displayed?
Old Sep 7, 2022 | 02:37 PM
memorizing a threshold
Originally Posted by pierrejoliat
Maybe someone used the tire sensing a lot, like the front left was leaking for a while and the sensor triggered frequently? mine in my '12 are still original, my '13 also. but it sounds like the battery is going dead. personally I would use OEM, I also though you could "calibrate" them on the dash while the tire pressures are displayed?
You're right, we get to select a set of threshold pressures in memory so TPMS system will trigger a warning below that limit.
The temperature is also available but only through scanner data.
Old Sep 7, 2022 | 05:01 PM
kajtek1's Avatar
For new sensors check with this ebay seller. I bought sensor from him for my Sprinter (full size spare come without it duh). and worked right away.
$15 for OE sensor is hard to beat and he is having deals on 4.
Check his store for sensors for different MY
1 NEW OEM ORIGINAL MERCEDES TIRE PRESSURE MONITORING SENSOR TPMS A0009050030 | eBay
Old Sep 7, 2022 | 06:50 PM
Quint22's Avatar
Veteran: Navy
2014 Cummins, 2014 E250 Bluetec
Thought there is a button in the glove box for resetting the tpms sensors or am i way off.
Old Sep 7, 2022 | 08:26 PM
Do you have a cluster with display menus...?
If so when showing pressures on display,
long press (x-?) to pop the reset menu question.
This relearns current values as base.
Old Sep 8, 2022 | 07:57 PM
Benz-LH44's Avatar
E Class
thanks for the link but I’m here in the UK. Might be more cost effective to find someone down here.
Old Sep 9, 2022 | 01:19 AM
kajtek1's Avatar
It is all subject to checking.
I've been buying MB and other parts in Europe and I have been sending MB parts to Europe.
Lot of new parts are sold much cheaper in USA than in other countries, so even paying extra for shipping makes sense.
Than in Europe I could buy small and/or rare parts that have never been sold in USA.
Sending part from NY to London can be cheaper than from NY to San Francisco in some instances.
Old Sep 9, 2022 | 09:44 AM
up_too_late's Avatar
2015 E350 4Matic Wagon, 2018 GLE350 4Matic
I have an Autel MaxiTPMS tool that has proven itself very handy with 5 cars in the family (each with a separate set of mounted snow tires). It will read pressures, battery status as well as program new sensors. I use it frequently to take tire pressure readings.
I also recommend their dual frequency sensors which work on nearly any car. I found a kit on Tirerack.com that comes with 8 sensors. If you need sensors too this is a good deal https://www.tirerack.com/tpms/detail...06&brand=Autel
Old Sep 9, 2022 | 10:18 AM
kajtek1's Avatar
Do your homework before spending money.
The site recommends me replacement MB sensors for $44 each for my dually Sprinters.
Mercedes never had sensors on duallies as 2 sensors close together will not work with directional antennas.
Old Sep 9, 2022 | 01:55 PM
konigstiger's Avatar
'71 Pinto
I suggest having codes pulled by someone with Xentry (MB diagnostics) ‘may’ need to replace auxiliary battery relay as recommended by attached bulletin. Reluctant to do so, if you want provide VIN I will supply correct MB part #s to shop tire sensors (should also pull aftermarket), relay and CU if needed.
File Type: pdf
