Sponsored by: CARiD
Upper radiator hose cold
Old Sep 13, 2022 | 12:51 PM
rwolak's Avatar
2003 CLK500, 2008 e350
Just did a coolanjt flush yesterday. Now the car overheats and the upper radiator hose (goes into the thermostat housing) is cold. Lower hose hot and fan turns on at high speed. Temp gauge goes to max. Everything was fine before the flush.
Any ideas????
Old Sep 13, 2022 | 01:29 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
refill skill...
too much air... not enough coolant.
Right now your coolant is not circulating properly, that's causing overheat: STOP!
The question is: how do you fill the block to radiator circuit when the cap and overflow tank is located remotely ?
The key is to get the air bubbles to escape
I guess.... you want the coolant service procedure to burp all air pockets out.
Old Sep 13, 2022 | 03:59 PM
rwolak's Avatar
so you have the procedure? I wasn’t aware there was one
thanx
Old Sep 13, 2022 | 04:05 PM
coolant bleed on WIS
I wasn’t aware there was one, thanx
submit your VIN# for a good soul to match your request.
Old Sep 13, 2022 | 04:10 PM
KlausPA's Avatar
E350 Wagon
Here you go: W212 coolant flush
