Sponsored by: CARiD
Rough 1-2 Shift
Old Sep 30, 2022 | 06:15 PM
ChuckinTucson's Avatar
2012 S63, 2013 E350 Bluetec
Rough 1-2 Shift
I have a 2013 E350 Bluetec. When I first drive it when the engine/transmission is cold the shift from first to second is rough. This will happen until the car has warmed up, then it shifts smoothly. All other shifts into the higher gears are smooth. It is only the 1-2 shift. I had the transmission serviced with new fluid and filter at my local dealership, but the problem is still there. The car has 87,000 miles on it, and according to the service records, this is the first fluid change, even though one was supposed to have been every 40,000 miles. I have only owned the car for a couple of months. Any ideas?
Old Sep 30, 2022 | 08:48 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
You have done all the right things to stay ahead of the ball. No one can question dealer service.
Your rough 1st-2nd shift is not common. Doesn't you car pick-up in 2nd gear already?
How many miles ago was that ATF service: over 5kMi already ? (adaptations)
When the ATF is still cold it is more viscous than at operating temperature. The valve body solenoid have a harder time delivering a smooth gear shift. (pressure difference)
Have you noticed if the low rpm shifts are very predictable or a little bit random rpm than they should? (PCV leak)
Be curious and indulge in car scans to check there are no faults on the ECU-TCU CAN-C bus.
Old Sep 30, 2022 | 10:01 PM
DFWdude's Avatar
2016 E350 Sport
I think the rougher than normal initial shifting is normal. My 2001 C-Class has done this all it's life... after this initial cold shift 1-2, all the rest are normal. My 2016 E350 is the same, although less pronounced. So, an initial rough shift when cold wouldn't concern me. Rough shifting when warmed-up would concern me.
Old Oct 1, 2022 | 12:00 AM
pain threshold....
You're right, I can see ignoring cold shifts to some extent... if it stays limited to 2nd clutch and not progressing
It's a bit low mileage to be banging already - My tranny shifts on its good days are seemless like a CVT
You can simply let your car warm up 5mn while cleaning your windshield and checking emails
Old Oct 1, 2022 | 01:51 AM
The ATF service was done about 200 miles ago. It started shifting rough which is why I took it in for service. After servicing the transmission and doing an adaptation reset, it still shift rough. All other shift except the 1-2 is very smooth. Someone mentioned if it started in second, but the car always starts in first, whether in C or S mode.
Old Oct 1, 2022 | 09:21 AM
AllPhonesAretap's Avatar
2013 W212 E350 RWD
CalibenzDriver, you always give very solid advice however, I'd like to respectfully dissent from your opinion in this case. Specifically letting the car warm without being under load. The gasoline dilution will put you on the road to bore scoring.
Old Oct 1, 2022 | 02:02 PM
interesting remark
I try to provide help like most good ppl around this forum - Everyone knows a thing or two about a thing or two! ✌️
You're saying that idling these cold engines to warm-up tranny ATF promotes bore scoring.
It could really well be that idle is bad!
We know the 2-stage oil pressure is lowered to a minimum and pistons are only get oil sprayed above 3500Rpm.
I am not surprised that poor lubrication can kill these engines, not sure if low emission mixtures washing down cylinder walls are part of this.
Where do you say we should look?
Old Oct 2, 2022 | 07:43 AM
S-Prihadi's Avatar
87K miles, how many years oil life that is ? Not 2013 to today .....right ? If so 9 years is way too long.
The dirt of 87K miles and 9 years could have provided good clutch traction when oil cold as extra FRICTION MATERIAL.
Now the oil is new, so clean, the clutch slips a bit and that jerky 1 to 2nd gear is what you feel.
Give it time for clutch to equalize, perhaps it will improve.
Honestly, pass 5 years and 40K miles if for my kind of traffic jam and hot ambient temp = BAD
My 1st tranny oil change was 10,000KM but at 4 years old, 2014 car, 2018 tranny oil change when I bought it. MB Indonesia told me its okey for 6 years and like 75,000KM ...now way.
The tranny response was so improved after 1st oil change.
Also : I hope you do not mistaken immediate reponse as JERKY/ROUGH.
Fresh new oil gives you faster response / gear change.
1st and 2nd gear are very low gear and lots of torque, it will have the most "jerk" when you apply enough accelerator pedal.
My tranny cold ( 30C / 88F not any colder ) is always OK. Your cold is how cold ?
722.9 Transmission Gear Ratios
First – 4.37
Second – 2.85
Third – 1.92
Fourth – 1.36
Fifth – 1.00
Sixth – 0.82
Seventh – 0.72
Reverse 1 – 3.41
Reverse 2 – 2.23
Source : https://www.transmissionrepaircostguide.com/722-9/
Old Oct 3, 2022 | 02:51 PM
konigstiger's Avatar
'71 Pinto
this is the first fluid change, I have only owned the car for a couple of months. Any ideas?
If they have not already done so request they revisit to check for software updates.
Old Oct 19, 2022 | 05:30 PM
JoelCrow's Avatar
2008 CL550
FWIW, my 2014 ML350, 2016 GLE400 and even the newer 2020-2022 GLEs that I rent on Turo (and one brand new GLS450 that I test drove) ALL do this. The smart thing to do are is to replace the fluid and have the service people reset the transmission presets to relearn your style (this DOES offer a 50% improvement). That has worked many times for me. But, the VERY BEST fix I've found yet (my experience that I'm sharing with you out of love for our collaborative enjoyment) is to actually run the car in "Sport or Individual (with Sport on engine)" drive setting. While you'd think the car would rev way up all nasty high in the RPM range and dog itself out like a 3cyl rental, it actually doesn't do that at all.... It seems to have about 4-5 different pressure-based (as in how hard you press the pedal) programs that it can run in throttle response in just the one Sport setting (it's adaptive)... So if you are gentle on the throttle (in SPORT) it will actually shift gears around 2,000 RPMs instead of the usual Comfort 1200 RPMs, and it completely skips over the crappy rough 1.5 gear that you feel jerking as you slow or just pull away. It works every single time for me now and it's become muscle memory... Put on seatbelt, start cooled seat, put car in sport, turn off STEWPID auto start button, put in drive and go!
Best wishes
Joel
Old Oct 20, 2022 | 10:50 AM
Fliplegend's Avatar
S212 E350 Estate
Not sure if anyone has brought it up but you are close to when the motor and trans mount is needing replacement. Could be contributing to the roughness.
Old Oct 20, 2022 | 12:32 PM
Best wishes
Joel
Thank you, Joel. I'm going to give this a try.
Old Oct 20, 2022 | 01:34 PM
KlausPA's Avatar
E350 Wagon
OP: Have you reset the transmission adaptive shifting?
