Sponsored by: CARiD
Getting check engine light code: P0356$07E8 and P0306$07E8 for 2016 E350
Old Oct 3, 2022 | 01:31 PM
park2k's Avatar
2011 E350
Question Getting check engine light code: P0356$07E8 and P0306$07E8 for 2016 E350
Help, my 2016 E350 wagon with less than 60,000 threw a check engine light when I started up the car one afternoon. It had been sitting for about 2 hours in the office parking lot and when I went out to lunch the car immediately had a very rough idle. I immediately put the car back in the parking spot and left it overnight to get my scanner from home. The next day, the check engine light codes are Module $07EB, $07E9, and $07E8 with the following codes P0356$07E8 and P0306$07E8 under Module $07E8. No other codes were found under the other modules.
The spark plugs were replaced at 45,000 miles.
I'm planning on replacing the spark plug coils. Double-check the spark plugs and ensure the gap is within specifications. Should I be looking for or doing anything else? Your advice is greatly appreciated.
Thanks,
Old Oct 3, 2022 | 02:34 PM
konigstiger's Avatar
'71 Pinto
P035607 - The actuation of ignition coil 6 has an electrical fault or open circuit mechanical fault.
P030600 - Combustion misfiring of cylinder 6 has been detected.
Old Oct 3, 2022 | 03:11 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
misfire electrical fault...
1- Swap the questionable coil with another cylinder
2- Reset active codes with scan tool
3- Does fault stay on cyl.6 or follows coil ?
The rubber boot is the fragile piece between coil to plug available as spare.
Get all 6 plus dielectric lube.
