Sponsored by: CARiD
W212 2010 E350 Transmission Dipstick location?
Old Oct 3, 2022 | 04:25 PM
VINESSEL80's Avatar
MERCEDES E350
So I have been trying to find the transmission dipstick location on my 2010 E350 4matic but cannot locate where it might be.
Anyone know where else I should be looking or is my car not equipped with one?
Thought this is where it was suppose to be
Further right
Left driver side by vacuum pump
Old Oct 3, 2022 | 05:23 PM
konigstiger's Avatar
'71 Pinto
Doesn’t exist, notice 10 in diagram is grayed out.
Old Oct 3, 2022 | 05:41 PM
VINESSEL80's Avatar
MERCEDES E350
Thanks, I was going nuts trying to figure out where it might be.
Old Oct 3, 2022 | 06:50 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
adding back the option...
Do you know if the optional hole in the tranny shell is caped by a plug -or not drilled at all.
Extracting ATF remains a perfect service to remove aged oil as witnesses on dipstick.
Old Oct 6, 2022 | 11:51 AM
atraudes's Avatar
2011 E350 Wagon, 2010 GL450
I had the exact same thought! Looks like it's not drilled, though. One might be able to drill it from below after removing the pan and filter, but the valve body might still be in the way.
I'll have to feel around the next time I'm under there to see if mine is the same case.
