Sponsored by: CARiD
Navigation stuck in Max Zoom Out
Old Oct 6, 2022 | 08:03 AM
2011WhiteE350's Avatar
E350
Exclamation Navigation stuck in Max Zoom Out
hi guys,
My navigation screen is stuck in max zoom out..
I tried to play around with the control but it keeps going in back to this screen..
Does anyone know what causes this problem?
Thanks.
Old Oct 6, 2022 | 10:18 AM
DFWdude's Avatar
2016 E350 Sport
Is this the screen you see when you open Navigation? Have you called up a "Last Destination" and tried to navigate to it?
IMA think if you start a navigation you might get the display range back. Just a guess...
Old Oct 6, 2022 | 07:54 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Crazy COMAND Zoom control...
The central console rotary control knob is a confirmed "solderless" module.
When its input signal gets disrupted by glitchy coms, uncontrolled zoom *may be* a result.
> Hook up a scanner to read fault codes from your COMAND head unit.
Old Oct 7, 2022 | 02:07 AM
BenzV12's Avatar
W212 FL
Houston, we have a problem (bottom left makes me say that )
Sorry for this prank but hope it would bring some smile on your face .
Well, back to the topic I don't know if it fixes the problem, disconnect the battery cable and reconnect it . Anyway, pulling the codes it throws any should be wiser too
Old Oct 8, 2022 | 04:24 AM
glenli08's Avatar
Mercedes Benz E Class E250 CDI BlueEffiency Elegance
Use Linguatronic
Hi there,
A way you might be able to change the map size is by using some Linguatronic commands like:
Zoom in
Zoom out
Zoom in on map
Zoom out on map
Hope this helps
Old Oct 8, 2022 | 05:04 PM
Polarbert's Avatar
W212 2011 E63
Is the scroll wheel working normally? Mine was broken so I had no control over how far the map was zoomed in. I replaced it with a metal one from ebay and now all works well.
