2011 E350 4MATIC - Chirping Noise from Engine Bay
New member so please pardon any posting faux pas. I have a 2011 E350 4MATIC with 80K miles. Since the past year, at startup, there is a chirping noise that has been coming from the engine compartment - please see attached video. The noise happens at startup and goes away when the car has been driven/warmed up a bit (it seems). I have had a few independents had a look but they have not been able to diagnose. The serpentine belt is new and the tensioner, I am told is also OK. Next step would be the dealer but want to see if this forum can help. Don't want give the AD a blank check to diagnose the issue - that will not be good for my wallet.
Thanks in advance for your help.
Can you do us a favor, please. This is for database.
I am speaking based on M276, but probably your M272 is very similar. I am totally not familiar with M272.
When you replace the 2 of guide pulley, can you observe the side of the pulley inner side ( towards engine ) does it have the dots like below on the pulley I marked R :
Please take note, which pulley location has its dots on the inner side.
For mine, brand new pulley so happened to be :
Pulley on top of water pump #6 has its dots on the outer side ( facing the bolt or radiator) and the pulley above the tensioner #7 has its dots facing engine block.
Pulley #7
Pulley #6
Secondly, when you remove the pulley, how is the bolt and its plastic bushing tightness towards pulley bore ? Can it fall off when held up side down, or is very tight ?
My old one is very loose and new one is very tight as such I do not even want to mess with the pre-inserted bolt.
My wear and tear of the pulley, is not from its bearing, but the worn out plastic bushing. As seen here : https://mbworld.org/forums/e-class-w...ml#post8636632
I do not have the chirp you got, but I can see belt movement is not super stable smooth for its "tracking".
See below :
Thanks so much for the trouble.
M276 no washer at the rear/engine side of the pulley, only at the front to push and make contact with bearing inner race.
