Arnott strut and bags too bouncy? (2010 E550)
2010 Mercedes E550
Just replaced my front right strut and both rear airbags with Arnotts. Noticed that the ride is very bouncy and feels like I'm driving a big boat. Anyone experience the same thing? Is there some type of settle time? Even the wife complained lol.
Received 4,435 Likes
'71 Pinto
Others should comment on personal experience. Just FYI Arnott should be replaced in pairs whether front or rear and offer both new & remanufactured parts not unheard of, although not common, for remanufactured to malfunction.
juanmor40 (10-26-2022)
2010 Mercedes E550
I was contemplating on replacing the front left strut too. Long story short, I bought the car January of this year. Based on the Carfax, both front struts were replaced in August of 2021. I called the Mercedes dealership where it was replaced and they confirmed it was replaced. I figured it was a faulty front right strut, but seeing on how they're in Miami and I'm in Texas, nothing they will do.
I've not had to work on my air springs yet... Does the Arnott integrate the shock and the spring? I thought it was just the spring, and there was still a separate shock absorber.
'71 Pinto
2010 Mercedes E550
Another note which I didn't mention and failed to remember is that I opted for the new OE strut as I couldn't find a reman. Apparently Arnott's new OE strut disables the active dampening system but keeps the ride height adjustment from sport to comfort and vice versa. I think I might of answered my own question, but damn I didn't think the ride would be this bad.
2010 Mercedes E550
I've been driving for a few days with the new strut and rear bags. No sagging whatsoever so I think it's fixed besides for the difference in ride quality. Also wanted to mention, I do have a lowering module, but the ride is pretty much the same on factory settings, low settings, and even a 1" drop on all corners.
an E550, so this has the active dynamic suspension? sure you used the correct Arrnott bag and not the one for the rear-only self leveling suspension?
I'm looking at the parts catalog, and it does appear ADS has both a air spring (A2123203725 left, and A2123203825 right), and a shock absorber, (A2123201530 left, and A2123201630 right)
on my wagon, which just has SLS, its left air spring A2123203925, right A2123204025, with various shocks for comfort vs sport.
2010 Mercedes E550
https://www.arnottindustries.com/amf...ic-2010-233491
I replaced the rear air bags in my wagon this past July with the same part numbers (2790/2791) and I feel like the ride may be a little more supple, but certainly no dramatic change. My bet is that the difference you are feeling is the loss of adaptive damping.
Raj1471 (10-26-2022)
There's only 1 set of choices based on Arnott's website. My rear bags are AS-2790/2791. Front right strut is an AS-3422 which should be a new OE strut without ADS.
2010 Mercedes E550
That's what I'm thinking now after making this post haha. I'm just going to live with it until I need to replace the fronts again, which I'll try to find the Arnott remans or fork up the cash for Mercedes OEM.
2011 E550 - 4Matic, 2008 ML550
Wait - can someone correct me? I did not think the W212 came with ADS - its only settings were - raise\lower and then Comfort\sport setting ?
Am I wrong?
Who as ADS and can show me - how you turn it on and off - I have never seen one before...at least on 2010 - 2014 E class models...or maybe just Euro or something?
Am I wrong?
ADS *is* that comfort/sport and raise/lower system, the other airbag system is what the 6 cyl wagons have, no controls at all, just rear automatic load leveling.
option code 489, AIRMATIC (air suspension with level adjustment and adaptive damping system (ADS))
looks like the Airmatic FRONT air spring+shock on a E550 is integrated, while on the rear, the air spring and shock are two separate pieces.. if you just replaced the air spring, your shock may not be working right.
I’ve had to replace leaking rear shocks on an Airmatic equipped MB, when the air springs were just fine. I bet that is the problem as Geek said. Too much rebound. You go boing boing boing.
