I've not used it for that, but it is much more capable than iCarsoft or BlueDriver. I would say that the LAUNCH scanner is as good as my Autel MaxiDAS DS808 scanner. If you get it through Amazon and don't like it, you can always return it.
(Currently, the LAUNCH scanner is $151 for Cyber Monday on Amazon.)
You can get the Benz, BMW, Audi (BBA) version for the same price. From what I can tell, the BBA is the full versions of each brand without additional purchases (or at least I hope so).
Only because is "Bi-Directional" means that it's just a garbage.
Any scanner is bi-directional even the ELM.
For receiving Fault Code date or Actual value, the scanner - any - should make a query. So send and receive, bi-directional.
Xentry is the cheapest solution and is the only one that has much more than any chinese spybots, besides Fault codes, Actual Values, Adaptations, schematics even with pictures, has conducted steps,
fyi, Launch makes scanners and scanner software for many other brands. There's a pretty good chance the SnapOn scanner is in fact Launch based.
Xentry legally is extremely expensive, with a 5 digit annual subscription... the cheap Xentry stuff you can buy as on ebay etc is pirated and hacked to disable the Mercedes copy protection and requirements for database subscriptions.
Snapon is a legit company, has nothing to do with Launch
Launch just use their own data base stolen by their bots, saving configuration from users cars and from SSD sold by well-known sellers.
Launch use Xentry cracked files together with spybots
Any cracked Xentry, that's not already installed on SSD with deep spybots can do 1000% much more than Launch "online"
Online on Launch only stole your car configuration, nothing more
If you install a cracked Xentry, with active Windows Security, it will cost 50-80$
Anyway, a legit Xentry system is 2000$ and includes Bosch VCI Doip interface with certification for latest vehicles, for diagnosis.
I don't know in US, but here is 12€ one hour of legit Xentry. In US should be the same.
For personal use, any cracked version of Xentry has the same legitness like an official Launch.
For Ford or any non-premuim brand, the Launch system can be the first option. A bigger part of my business make money reviving ECU'S after Launch.
Ex. when you switch options it may mismatch config that become a proverbial "bricked" module.
JTAG becomes necessary on bricked circuits that can't boot.
Me like better soldering iron for performance enabling stable CAN bandwidth.
you think Snapon themselves makes diagnostic electronics? hah, they make wrenches and such. The electronics diagnostic stuff they sell is all built by others and rebranded SnapOn
Mercedes use Snapon and snap has all MB licenses
yeah, Snapon buys Mercedes Vario and Atego Chassis Cabs for their franchisee's tool delivery trucks. Whats that got to do with motor diagnostics ?
They received from MB the official data base for their genetic scanner
All that can be found on MB B2B portal.
I work every absolutely day with damaged ECU's by Autel/Launch, I know what they delete and how they do spybot.
For me it's a good business, most of the ECUs can be reflashed with DTS ...but not all.
Of course using Launch is preferable for users without experience as it's easy to use, but exactly those user's will always want to use "advanced function" and not only because Launch has nothing to do with logic procedures but because the user has no knowledge they will trust only the meaningless instructions from Launch.and ..boooom!!!
FYI today I made the coding changes for the High Performance Package. This is on my E250 Bluetec. Car definitely seems quicker and more responsive; without question able to get to redline sooner.
For any who are interested....first make the change in CGW (variant coding/global variant coding). Then make the change in ECU (variant coding/implicit variant coding).
I'm curious to see what anyone else experiences making this mod.
The code number "B28B6S2" seems to mean "Remember" in ECU terms
That is correct. I confirmed by looking at my car, which I had used the Mid City Engineering device to set my Start/Stop to Last Remembered. My code was B28B6S2. You do have to click on the alphanumeric code to drop down the other codes, ending in S0, S1, and S3.
Awesome stuff : ) no errors right? Did a backup just in case?
Thanks for confirming : )
ALWAYS back up before making any changes. I did not use the scanner to change my Start/Stop settings. Instead, I had paid $150 (plus shipping) for the Mid City Engineering device. I paid that twice for two cars. This was before I knew there were other options, like BenzNinja or the LAUNCH scanners.
yeah all good after one day and many restarts.
The hard part was finding the path to get the menu and what code combination gave what ECO setting.
I think there is a use case for ECO to calibrate battery charge level.... meaning once a while (daily/weekly/monthly) it may be good to perform a ECO cycle at the light when engine is cold to prevent unnecessary heat soaks.
These cars definitely like goood chassis voltage.
< Go Team MS! >
< Go Team MS! >
Do you remember what path you used to get to Start/Stop? I kept on getting "Communication Error with ECU." But when changing from 3 to 5 clicks on turn signal blinkers, it was a straight shot and no errors.
Just in case, be certain the following:
1 - When the scanner says Ignition OFF -> key off
2 - When the scanner says Ignition ON -> key in position 2, engine OFF ; otherwise, the scanner cannot write to the ECU -> communication error.
