Sponsored by: CARiD
2013 E350 major service
Old Jan 1, 2023 | 02:32 PM
skidaddyoo's Avatar
Veteran: Air Force
2013 E-350 sedan
Hello everyone, I’m having major service done on my 2013 E350 sedan (69K) by my local Mercedes dealer. I asked my service manager if it includes changing the transmission fluid and he replied “that comes later”, can anyone tell me what this service should include? I thought all fluids should be replaced? The dealer estimate cost for their service is $1,600
Old Jan 1, 2023 | 03:45 PM
Sunnyslope48's Avatar
2016 E350 Sport 2WD
I believe my 2016 E350 calls for fluid change at 60K, and I did that myself. I would have them change the tran fluid if it has never been changed. I hope their charge for the fluid change isn't the $1600 in your message.
Old Jan 2, 2023 | 09:37 AM
KlausPA's Avatar
E350 Wagon
The dealer is the only one with an answer. In my opinion, a service worth $1,600 should cover a lot. Did you get an itemized work order?
Here's the basic information about services: Services to Keep You Going
Here's a nice write up about your transmission, including the service interval (70k miles): Mercedes-Benz 7-Speed Transmission (722.9) Service Walkthrough
Old Jan 2, 2023 | 09:39 AM
KlausPA's Avatar
E350 Wagon
Sunny I share your view mate, transmission service is cheap compared to transmission failure.
Old Jan 2, 2023 | 10:32 AM
chassis's Avatar
2017 GLE350 4MATIC
Before proceeding, require the dealer to give you a written itemized estimate. This doesn't smell good that he didn't directly answer your question.
Service is mileage-based or every-two-year based. Regular service is a nothing burger from a time+effort point of view, so if you are out of warranty, DIY or indy shop is recommended.
Mileage:
10k miles: engine oil and filter
50k miles: engine air filter and spark plugs
60k miles: transmission fluid replacement
150k miles: coolant replacement and fuel filter replacement (not 100% sure on the fuel filter)
Every-two-years:
Cabin filter(s) and brake fluid replacement
When needed:
Brake pads and and rotors, tires
Main battery and auxiliary battery or voltage converter
When/if desired (I recommend all of the below):
Axle(s) fluid replacement
Poly-v belt replacement
Belt tensioner and pulleys replacement
Ignition coils replacement
If needed:
Cam magnets
Cam position sensors
O2 sensors
Old Jan 2, 2023 | 03:53 PM
konigstiger's Avatar
'71 Pinto
276 engine, transmission oil/filter is every 70,000/7 years see attached service sheet.
File Type: pdf
Old Jan 2, 2023 | 04:38 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
My mistake. Delete it accordingly
Old Jan 3, 2023 | 01:57 AM
nightspd's Avatar
2016 E-350
But for 2016 I believe they reduced the transmission service interval to 60k.
Old Jan 3, 2023 | 05:57 AM
ZakiGarage's Avatar
E300 w212 | E46 BMW | Golf MK5 | Toyota Tercel | Dodge Intrepid | CBR600
Read on a service booklet that transmission oil should be changed every 50k km, the dealership used to do this service on my w212 every 60k km.
Now I service it every 50k km.
Old Jan 3, 2023 | 04:55 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
yes, they did. 6 years or 60000 miles.
Old Jan 4, 2023 | 05:46 AM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
Good lord thats steep. Where in Northern CA are you?
I recommend this shop, they can cut that price in half and the service is better than my personal MB dealer. My local dealer has a cute girl in parts though.
https://www.yelp.com/biz/mercedes-ex...ara-2?start=40
My local dealer will pretty much fib to get out of doing trans service, they do not like doing it, do not follow the official MB bulletin for changing ALL of the fluid either, unless you confront them about it.
