Mercedes in limp mode after timing chain replacement, also blows no heat.
Greetings all!
I have owned my Mercedes E class (2009 however it’s the w212 version) for nearly 4 years. The most recent problem that I had, was that the timing chain tensor failed, due to the lack of service from the past owners i suspect. The car had no problem until then, engine wise, however after getting the whole timing kit replaced, I turned the heat on and the car was blowing no heat, just a little bit of coldish air, and shortly after the car threw a check engine light after about 15 minutes of normal driving, and went into limp mode. I will also mention that I told the mechanic to replace whatever was making the coolant leak, however he decided that it wasn’t worth it and just threw in some anti leak liquid into the cooling system, which I suspect probably cause the heater core/ heat exchanger to clog. I went back with the car to ask the mechanic why this happened straight after, however all he done was put a code reader on the car and say it was a DPF fault, keeping in mind that I replaced the DPF less than a year ago. I’m just wondering, did anyone else have any problems with the car after getting the timing kit replaced? What could i try to remedy the problem?
Thank you!
Thank you!
biker349 (01-02-2023)
2013 W212 E350 RWD
Greetings all!
Thank you!
Thank you!
When the tensioner failed, did it make the piston meet the valves? That could be why the mechanic said screw you...
SPONSOR
11 E550, 16 AMG GTS, 13 S550
This sounds silly but could you have air in the cooling system?
Could be a heater control valve, but it'd need to be looked at. The internet is great for some things, not for everything.
The following 3 users liked this post by ChrisHimself:
Hi,
The pistons did not have contact with the valves since i turned off the engine instantly and couldn’t hear any knocking or pressure loss sounds after the car has been “repaired”. Also, the mechanic said he had a look and everything internally seemed fine. However now the gearbox feels sluggish, doesn’t change gears properly but the car pulls like it never did before. You think there was a possibility that the transmission hasn’t been connected properly after the engine was put back in?
AllPhonesAretap (02-02-2023)
Received 3,392 Likes
MY'14 W212 M276 3.5NA @60kMi
¿ Scanner time or ??
Did you have a chance to get the FAULT CODES PULLED... It would not surprise me to find the ISM-VIP at the center of your topic - Let's find out, ok?
With data you increase your chance to get closure
THE EASY FIX FOR THIS LIMP MODE SHOULD BE A SAFETY RECALL
Did you have a chance to get the FAULT CODES PULLED... It would not surprise me to find the ISM-VIP.
Greetings all!
Thank you!
Thank you!
the engine is turning around several thousand rotations per minute when you are driving. 2000 RPM is 33 rotations per second, and each rotation, all
The following 3 users liked this post by Left Coast Geek:
