Sponsored by: CARiD
Gasoline additive
Old Jan 29, 2023 | 10:48 AM
Chamz333's Avatar
2011 w212, 2018 W166, 2024 v167
Gasoline additive
Hello all what gasoline additive did you guys use and worked really well in you W212
Old Jan 29, 2023 | 12:40 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
Gasoline additive? Why?
Diesel, sure. Gas? No need.
Old Jan 29, 2023 | 01:11 PM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
Depending on where you are in the world - a gasoline additive may be needed. If you're in North America - visit https://toptiergas.com. In my early days at Bosch - we worked extensively to approve Techron for use in BMWs. Tricky exercise as the manufacturer of the injectors and not wanting to imply a defect that needed to be cured with a fuel additive, nor imply an engine design defect, etc. But we got it done and Techron was the formulation. It then became part of advertised gasolines. That was all taken over on a much grander scale in the form of top tier gasolines where vehicle and equipment manufacturers write and enforce the standards. Mercedes-Benz is one of those manufacturers.
Old Jan 29, 2023 | 01:59 PM
Chamz333's Avatar
Thank you
Old Jan 29, 2023 | 02:03 PM
Chamz333's Avatar
performance degraded have rough idling. We constantly fill up at Sam’s Club and I think their Gas is not Top tier .. and I guess the car built up some carbon deposits that I need to clean up
Old Jan 29, 2023 | 02:11 PM
konigstiger's Avatar
'71 Pinto
Although 212 not listed due to release date: Techron.
Old Jan 29, 2023 | 05:24 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
sounds like it needs an 'Italian tune-up', borrow the car for an afternoon, and drive it hard, keeping the revs up for extended runs at speed. Do this about once a month for ongoing maintenance.
Old Jan 29, 2023 | 05:30 PM
indeed, Sams Club / Walmart is not listed.
https://toptiergas.com/licensed-brands/
Costco's Kirkland is, however. We use Costco Premium as much as practical. It helps that its the cheapest gas in my area.
Old Jan 30, 2023 | 12:56 AM
95Sinned420's Avatar
2016 S550
The only thing I could recommend would be Techron. However, don't think that it'll clean valves etc on direct injection engines.
I'm quite skeptical of snake oil and other additives that they try to sell you. However, from personal experience, Techron works. Over a decade ago, a co-worker sold me a W140 S420 that was running rough, for a really cheap price. I knew it needed A LOT of work, but the price was a bargain. The first thing it needed was a tune up, I knew it'll need at least spark plugs and maybe dist. rotor and cap. When I first got the car, I poured one bottle of Techron into it and to my surprise, that cured the rough idle.
Old Jan 30, 2023 | 02:08 AM
This is old school advice from various mechanics I've known, but if you run the Techron Concentrate, the recommendation was, larger bottle of Techron in the tank, and half fill the tank with gas, then run that tank out keeping the engine at as high RPMs as practical via manually downshifting, til the tank was mostly empty, refill the tank, drive normally another day or two, then change the oil and filter. yes, this involves an all day several hundred mile joyride.
Old Jan 30, 2023 | 04:04 AM
ZakiGarage's Avatar
E300 w212 | E46 BMW | Golf MK5 | Toyota Tercel | Dodge Intrepid | CBR600
I don't really have an option on these additives but looking at my old MB dealership receipts they would add the MB brand fuel additive with every service.
And some of my other non MB cars have it on the service interval to use the fuel additive every 5k.
So I just have a 24ct box of the cheapest additive I found at the time (liqui moly) and just add it with every oil change I do now, never felt a difference on any of the cars.
Old Jan 30, 2023 | 02:10 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
, Definitely
I have used the Sams Club gas since 2017, @6 years, and I have not noticed any issues.
I use Techron if the car's tank is half or less, top it off, and I am traveling longer than 1 hour, plus the Italian's tune-up if the traffic permits (hopefully @midnight )
Old Jan 30, 2023 | 04:38 PM
Aussie_E350_Wag's Avatar
2013 E350 Facelift (Japan Import) 2007 E350 Elegance Wagon, 2014 E350 Wagon facelift model Jap Model
Thumbs up
Wow, same here in Australia, I have a few high powered old Mopars with cranky 440's in them and we only ever run Costco 98 in everything we own and its just brilliant, Shell & BP are trash!!!
Old Jan 30, 2023 | 05:52 PM
DFWdude's Avatar
2016 E350 Sport
Just paid $2.49 per gallon for 93 octane Premium at the Tom Thumb gas station associated with my Tom Thumb Grocery store, where I score $1.00 off per gallon. I presume it dispenses no-name gas (certainly not "Top-Tier"). But I don't know for sure, since I am never there to see the delivery tanker on site.
I've had ZERO issues with engine performance... no hard starts, no idling problems, no stumbles, etc. I don't use any additives, either. I did use a bottle of Techron once, just to see what all this periodic, repeated blabber is about here. Made ZERO noticeable difference, so I haven't used it since.
I guess some of us are just lucky. Naw...
Old Jan 31, 2023 | 06:42 AM
Dane500's Avatar
2013 E550 Sedan, 2005 E500 4matic Wagon
"Top tier".....
I see the same trucks in my area filling the tanks at every station. So take "top tier" with a grain of sand.
Old Jan 31, 2023 | 08:27 AM
DFWdude's Avatar
2016 E350 Sport
Originally Posted by Dane500
"Top tier".....
I suspect this is true in my area, as well.
Years ago, on a long-distance drive between St. Louis and Orlando, FL (going to DisneyWorld), I refilled my minivan's tank in Georgia at a Chevron station. This "Top Tier" station did not sell me usable gas... more like watered gas. I sputtered down I-75 for hours. until I topped up with better fuel in FL.
One can get bad gas anywhere, I suppose. But if "Top Tier" means you have better confidence in a branded gasoline, this time it failed. I haven't patronized a "Top Tier" Chevron station in the 28 years since...
Old Jan 31, 2023 | 10:08 AM
nc211's Avatar
2020 GLS450 (wife) / 2024 Ford Bronco (mine) / 2014 VW Tiquan (son)
I’ve had good luck with the Gum Out with PEA stuff in my cars. Maybe a bottle every 5k miles or with seasonal changes to make sure no condensation (water) build up sits in the tank for long.
Old Jan 31, 2023 | 11:55 AM
Top Tier stations will have a sticker on the pumps proclaiming as much. The additive is metered into the gas as its put into the station's tanks. Ditto, if the station sells midgrade, that's typically a 50-50 mix of high octane and low octane.
Old Jan 31, 2023 | 01:06 PM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
Top Tier, now thats funny, we have a BP, Sunoco, Shell and Marathon refineries here in CLE, all the gas comes from those four refineries, additive packages are dumped into the tank in packets while the truck is filled, if it's going to off brand stations, a particular section of the tanker is given a different additive package. most off-brand stations will buy based on price from all four and usually accept that particular brands additive package, tomorrow may be a different refinery that was a penny less so could be many different refiners additive packages in the tank at those stations, The branded stations only use additives for their brand, RBOB is RBOB. All gas is made to a minimum standard, the only difference between BP, Shell, Marathon or Sunoco, Valero is the additive package.
Same thing is true for ethanol, today may be Cargill, tomorrow may be ADM, or a local small producer, once the truck is QC'ed at the inbound gate, it all goes into the same tank,
For you left coasters, most of your ethanol comes from Pacific Ethanol, 2-3 ethanol plants in Cali, for you Bay Area guys, it comes from Stockton.
Old Jan 31, 2023 | 01:18 PM
I asked the guy filling a station once (because I had to wait for him to be done, I was on fumes), and he pointed to the on-truck additive mixer. He flips a switch, its 'generic' Top Tier. Another setting, its Techron for a Chevron station. We have two refineries in greater SF Bay Area, Chevron and Tosco. Chevron stations always get filled from the Chevron refinery, everyone else can buy from either. Ok, "Tosco" is owned by someone else now, but everyone still calls it that.
Old Jan 31, 2023 | 01:30 PM
Santa Maria and Rodeo are connected by a pipeline, operated by Conoco, so the gas from each can be produced at either. One refinery owned by Chevron, the other by Phillips 66, a spin-off from Conoco.
Old Jan 31, 2023 | 04:11 PM
Actually, the crude comes from Santa Maria, and is partially processed down there, then pumped north to Rodeo in the SFBA where its refined to Gasoline.
Rodeo is a 3rd refinery I forgot to mention as I rarely hear of it. Its less than half the capacity of the Chevron Pt Richmond facility.
Old Feb 1, 2023 | 01:04 AM
BenzV12's Avatar
W212 FL
No additive , just premium for me . I'm not strictly against any additive products either
