Battery concern
Thanks in advance for your help.
Not sure what battery health check was done to your battery, but the "MB approved" test at dealerships uses Midtronics equipment. I have seen some stores using such testers when checking batteries: SamsClub, Walmart, and Battery Plus. Some of them can print their reports, and you can then read the current CCA available. There is no amount of battery tender/charging that reliably guarantees an old battery will start every time your wife needs the car.
For your peace of mind, if the battery is the original, just change it and use the maintainer now. I have never used the Schumacher, I do own a CTEK (which seems to be the one MB uses)
But yes you can trickle charge it while attached to the car, it's how they were intended to be used.
TO keep battery fresh as car sits.
1.5A 6V/12V Fully Automatic Battery Companion® | Schumacher Electric
In my W212, the Comand system refuses to boot up at engine start (when working at shutdown) when the battery is low. This is my indication that the battery charge is depleting. No tunes on engine start > time to recharge the battery.
I keep a Stanley battery charger on a stand between both cars. The Mercedes has never failed to start, even when "low," although the Shanley charger sometimes shows just 20-25% charge state when first connected. The main battery is now 3 years old, and I have learned to accept the constant energy depletion in this 4-wheeled computer.
For my Birthday in Nov., I treated myself to this highly-rated GOOLOO GT3000 (3000A 100W) Jump Starter/Battery Pack. Available at Amazon.com.
The 8 year-old battery in my 2014 Hyundai Sonata failed to start the car just 3 weeks ago, and the stand-alone GOOLOO could not have been easier to use with excellent results. It works a peach without a jumper car in sight, so I will take it with me for long distance travel in future, along with back-up jumper cables in both cars, of course.
In short, there are plenty of emergency solutions available today, so I think it unlikely that a dead battery will ever strand me alongside the road in future. And I can easily recharge the battery in either car when I park it in the garage at home.
