SRS error code
Received 4,516 Likes
The following 2 users liked this post by S-Prihadi:
juanmor40 (01-23-2023),
Left Coast Geek (01-23-2023)
ok, I got that orange cap popped out and unplugged the cable. ohm meter read continuity on the two pins of the squib (it read about 0.5 ohms but its not very accurate on low ohms). I didn't try and read bias voltage on the wiring side
I think the Bias voltage can not be read with a DMM, you need a scope.
It probably uses the small signal pulse like how ECM test its sensors. Low voltage and very low power and fast short signal, otherwise the pyrofuse will BLOW ... he he he.
I do have an old fashion analog oscilloscope... haven't fired it up in about 10 years. its rated for 20Mhz ...
CRT version, sweet
yeah, its probably late 70s/early 80s. its just a cheap BK Precision, 'student grade' as it were, not a proper Tek or HP. A friend was cleaning out his old shop and gave it to me about 10 years ago.
