SRS error code
SRS error code
I just got my Launch Creader Elite Benz, and first use I'm quite happy with how well it works.
my wife's 2016 E350 4Matic wagon has been throwing an error on the dashboard for a few weeks now, that the SRS System is disabled.
The Launch says, its SRS N2/10 code B273513 "The squib for pyrofuse "On-board electric line" has a malfunction, there is an open circuit"
googling suggests this 'pyrofuse' is on the main battery plus lead, and is designed to go off if there's an airbag event, to disable all electrics in the car. The error suggests its a wiring iissue with the triggering squib, so when I have the time (wife has car on errands now), I'll dig farther. I already found and spliced one rat-chomped wire pair near the battery... maybe my crimped splice sucks, and I need to do it over with solder and shrinkwrap
pierrejoliat (01-22-2023)
Correct, you need to solder and wrap. This is all your fault.
Received 4,516 Likes
Sweet... best US$140 scanner you have
Received 3,611 Likes
MY'14 W212 M276 3.5NA @60kMi
pyrofuse fault
LCG, great you've done almost the whole job but your Santa-Cruz rat had a serious appetite for more Benz wiring.
Keep the heatshrink option on the table for now. Have you tried to match wiring colors to SRS diagram?
and indeed, the chewed wire pair IS the squib wires to the pyrofuse on the battery positive terminal, white-green and violet-blue... Now I need to find my soldering stuff, its been a couple years.... k, found.
took apart my original crimp repair, soldered and double shrinkwrap, and clear the fault, and its STILL throwing the same fault, and if I read the live data, it says its open circuit. grrrrrrr. These squib wires go directly to N2/10, the SRS control unit, which I believe is behind the lower center dash, forward of the ashtray.
now I'm stymied.
now I'm stymied.
Testing time...
now I'm stymied.
now I'm stymied.
A rat chewed the pyrofuse wiring pair. It's now reliably patched but same SRS fault keeps coming back.
> What could the rat do:
A - Not only opened but shorted wires together?
B- I do not think rat disconnecting pyrofuse control could kill pyrofuse circuit with it still conducting normally. So if harness is testing fixed with continuity, the next issue is inside SRS controller.
> What style circuitry:
- Fixed steady +12 through a fuse or micro trace
- Switched GND through 10¢ power MOSFET.
> Meaning of Fault :
The SRS is not seing +12v show up on the switched side coming through the pyrofuse back into SRS.
> What to do next?
If wiring has continuity, now focus on SRS box...
1- Test the harness supply side for missing power. You can do this right at pyrofuse terminals.
2- Invite yourself inside N2/10 for a visual inspection. Disconnect batteries!
You're right about SRS being located behind ashtray.
This is when pieces start flying out.
a squib is pretty low resistance, and I can't really picture a short doing any damage with the residual level of current they would be using as a continuity test.
there's no connector on the Pyrofuse side, and I shrink-wrapped my splice, so it won't be easy to 'ohm' it out. I probably should have tested things before I spliced it.
I have zero desire to go spelunking in the center console of the car to find N2/10 in order to do any tests from that end.
off limits?
Getting the astray sliding doors gismo out, I think will provide some form of access to SRS.
These modules are not frequently worked on, supplier knew better than to use solderless connectors. They are located in the safest location.
geez, the pyrofuse is not a separate part, its part of the positive and starter cable assembly, a nice $300 part.
Received 1,640 Likes
2008 E350 (W211 @170K), 2012 ML350 (W166 @119K), 2014 E350 Sport (W212 @96K), 2015 ML350 (W166 @92K)
@Left Coast Geek I came across the following discussion,
and I thought it could help finding out if the problem is at the battery terminal side (saving work under the dash). However, I am not an expert on this matters and I rely on @CaliBenzDriver for advice for this type of things. So, Cali you are next (again)
The following 2 users liked this post by juanmor40:
CaliBenzDriver (01-21-2023),
A previously owned matching part should not require any coding, you know like an eBay deal can quickly give you peace of find to go focuss elsewhere.
For free you can probe your wiring with a sewing needle... Diagnose-Dan does it with no shame: Unlimited supply for 5¢✌️
Ps: pyrofuse must be a low R heater link, say below 500R - A pretty rugged link.
The following 2 users liked this post by Left Coast Geek:
CaliBenzDriver (01-22-2023),
loose pyro plug??
The facelifted cars have a prefuse cover to plug the missing pyrofuse hole.
The good thing about these pyrofuses is they have no way to blow up like airbags... "safe" to work around.
@Left Coast Geek , sure you have another scanner with MB features. Have you tried deleting the code with it, not the new scanner?
Just mention because https://mbworld.org/forums/e-class-w...ml#post8288961
Master Lou found already two problems with new scanner, maybe you found a 3rd one
ah, no, I don't have another scanner, but that thread sounded like he was having problems with the ICARsoft thing. I have the new Launch Creader Elite Benz/Sprinter..
but yes, when playing with this one, it threw a few phantom codes, somethiug about outer left front radar (wtf, I ain't got no radar?!?). It seems to work better if I turn the car on without starting the engine before beginning a scan cycle.
anyways, gonna check that blue-yellow plug on the Pyrofuse tomorrow... too dark and cold now. Thats exactly what mine looks like. I gently poked/wiggled at that blue-yellow thing when I was in there this morning, but didn't realize it was a plug.
so here's the pyrofuse, and my splice (under the green shrink-wrap on the right),
and here's a closeup of the squib connection...
if that blue-yellow thing is a plug, I'll be darned if I can figure out how it disconnects, it seems very solidly on there.
SRS-Caution territory
I see you really want to unplug your pyro pigtail... to work the plug out, you want to first first release the orange locking pin on top.
What to expect on that twisted lineset?
> I think a fixed GND with a gated DC12V anytime you wish pyro fuse to say sayo-nara
> or a full time 12V line plus a switched GND control.
Plan-B : poke through splice work....
> Give the wife's car another beautiful splice job
> peel/remove outer insulation
> poke at each individual line without short-circuiting them.... what do you get?
in addition to whatever it is that fires off the pyro, its also monitored, which means they are running a small current through it to detect its connectivity.
CaliBenzDriver (01-23-2023)
I am not expert on this; however, from what I read the two thin wires connector with the orange plug, the squib, is monitored as you mentioned. The module expects a resistance around 3Ohm.
Does the squib feels tight to the terminal? Is it making "very good contact"? Could it be that while splicing the cable something else got loose around there?
Say I were to cut the wires, and measure the resistance of the squib, I would expect 3 Ohm: otherwise the squib is faulty. If you get 3 ohm, then the issue is upstream, i.e. the splice is not providing the right resistance from the module to the squib. It cannot be lower since it is in series; therefore too high resistance.
Reminder, I am electrically challenged , so take with a grain of salt.
the plug and the wires into the plug feel very snug and secure. but I didn't realize that orange cap on the side is a locking pin, so I'll look at that tomorrow.
Only way I'm going to be able to ohm the squib is to either disconnect my splice or unplug that connector.
Home sweet home.........
This is the expected value by Xentry, all under 3 Ohms if possible. I now, sometimes do not trust Xentry Specified Value 100% anymore as I have seen it is placing kinda generic data for many models, granted for some components only.
Will the code not clear itself after so many drive cycles?
