S550 wheels
WIDTH FRONT 8.5 AND REAR 9.5
OFFSET FRONT 36 AND REAR 43.5
...but not too long as you can ruin the rear brakes if they are too long
when you put the bolts in the wheel(off the car) they should stick out the back of the wheel about 1/2"(13mm) - 3/4"(19mm)
If you're wondering, that's my 1986 Starion/Conquest project and my 2000 Saab 9-5 Aero wagon with a manual and all the bolt-ons, cams, fuel pump, tune, suspension, that's turned into a project.
You can still put the same tires on different rim width.
The key to success is matching RPM. Common knowledge is that the system will accept up to 3% difference, before CC stop working and lights will go off,
