Brake rotor size E550 4matic bi-turbo
I need to replace the brakes on my E550 and am seeing 360mm and 344mm for the fronts and not much info on which came on the turbo model vs. the 5.5L model. Can someone tell me which size I have, and if it's the 344mm can I swap in the 360mm stuff without issue? Thanks
Received 4,435 Likes
'71 Pinto
Provide VIN.
If you remove the wheel you'll find the the part number on the old disks assuming they are MB brakes. Or a vin look up on MB parts software.
'71 Pinto
See attachments.
