Steering Wheel Upgrade: s-class to e-class
I’ve done some searching but haven’t found definitive confirmation that an s-class steering wheel I’ve been eying will be a direct plug and play replacement for my e-class wheel.
Not looking to modify any wiring or electronics, car has 85k miles so slowly trying to refresh some worn interior bits.
S-class wheel PN: 001-460-25-03-9E38
My VIN: WDDHF6HB0FB090943
Both wheels have heat, lane assist, paddle shifters.
Current wheel(stock photo):
New wheel:
Thank you in advance!
New wheel:
the controls on the W212 E class steering wheel speak CAN E to the Front SAM. I have no idea if the S class uses the same CAN endpoints and protocols and stuff. Everything has to be coded to match to even swap those parts between different E class cars of the same series
BenzV12 (02-01-2023)
youll need to swap your existing control module and modify the wiring along with pinout. will be pretty extensive work
another option is upgrading to a newer wheel, i have all the proper modules and decoders to make the wheel plug and play.
You can even have present W177 A Class , CLA steering wheel or probably W206 C CLass if you like .However, if I were you I would pick W212 AMG E63 steering wheel both top and bottom are cut
Received 3,392 Likes
MY'14 W212 M276 3.5NA @60kMi
mismatched = useless ?
Are all the new wheel controls essentially useless if existing modules have no support for new features.
I looked into these wheels as well, however they don’t offer the heating element for e63 models - at least from what I’ve read
