Serpentine Belt
I think it's a sign your belt is rubbing on something. Have a careful look around and see if you can figure out what it's touching.
If that all checks out, take a look at all of the flat-faced pulleys and see if you can find anything unusual.
Chamz333 (02-27-2023)
What's the mileage on the car? The M272 is well known to chew up tensioners and pulleys. I'd just throw in a new set if you haven't done it in a while. I think OEM might be INA or Gates. You can either get a whole kit or get the parts individually. Did one car about 7 years ago and they're still holding up. The INA kit from Rockauto is about $120, a little less after using a 5% discount code you can find on retailmenot.com, but only has a one year warranty. Or you can get a kit from FCPEuro for $150 and that would also have a lifetime warranty. Or you could try and figure out if it's the pulleys or tensioner but I think it's just easier to replace them all at once instead of just doing one and then doing another a little while later.
https://www.rockauto.com/en/moreinfo...11659&jsn=1079
https://www.fcpeuro.com/products/mer...-272273beltkt1
