E220 SE ABS Fault & Traction Fault
C04AE00 The signal from component 'L6/1 (Left front axle rpm sensor)' is faulty
U140900 An implausible left front wheel speed signal was recieved
U010100 Communication with Control unit 'Transmission' has a malfunction
U041600 Implausible data were recieved from control unit 'Traction Sytem'
U045A00 Implausible data was recieved from control unit 'Parking Sytem'
The last Three codes only clear on seconed attempt and once car reaches 20mph, all codes re apear.
559916 The battery of the tire pressure sensor has a malfunction. The limit value for electrical voltage has not been...
I presumed tyre pressure issue has nothing to do with this, tyre pressure still shows correct on dash
Any help or advice would be gratefully received, Thanks in advance.
From here we can guess it may be something else causing this issue. It does seem like a few modules getting upset. It's only normal here for tranny to complain about missing wheel speed.
Can you have a look at ESP wheel speed data to confirm where info gets lost.
C04AE00 The signal from component L6/1 (Left front axle sensor) is Faulty
On live data speed will go the same as other three wheels upto around 15-25mph then fault comes on and speed will show 40723mph and will stay like that until codes are cleared
Inspect ESP connector for crusties. Inspect harness for integrity all the way down to wheel. Scope Left vs. Right side wheel sensor input.
