W212 car engine dies randomly
The diagnostics suggested that pressure pump was faulty, this has been changed but the problem still persists.
Any help will be greatly appreciated.
Thank you
Thank you
Engine dies randomly while driving regardless of new high pressure CGI petrol pump.
Stop replacing good parts! Instead look for evidence to troubleshoot faults.
The age old question is to figure what goes missing: gas supply or ECU spark power?
I am going to guess your mechanic picked up on clues for low rail pressure and devided to replaced your pricey pump.
Following current direction without any active fault report, I'd scrutinize the output of the low pressure in-tank pump (look for supply in the 70psi range).
If fuel delivery checks out fine then something electronic maybe actively disfunctioning. It's nice to note your engine always restarts instantly - Help us help you save ressouces: SCAN YOUR CAR for faults!
I wonder why is your HP fuel pump was replaced first and not focus the attention to LP fuel pump and the fuel filter first ?
LP fuel filter will clog first before HP fuel pump get worn out.
Becareful of fuel starvation to HP fuel pump, it uses the gasoline it pumps as its own piston lubrication. The main gear to camshaft is oil lubricated, but the actual fuel's High Pressure pumping is gasoline lubricated.
attached is M271 EVO tech manual for your reading
