Auxiliary battery
I bought recently my E350 2014 , I have popup message in white color that auxiliary battery malfunction and ECO mode in yellow color. As far as I know that auxiliary battery is for ECO start/stop function, is that used for something else and how it safe to keep it for a while.
Another question as I wish to disconnect it to charge it on charger for a while so is it safe to drive the car when I remove the battery until it charged.
The connecters is salty too much what can I use to clean it.
Thanks in advance.
Thanks in advance.
You can easily charge the OEM vented AUX battery inside the car using a CTEK charger set for "small Batts". It vents any flammable hydrogen outside the trunk.
The car itself charges the AUX. battery at every driving cycle.
AUX not being charged normally, may be sign your MY'14 has charging issue with ECU draining batteries while driving.
Keep an eye on MAIN battery voltage, AUX is charged/discharged from it.
Main battery is fine as this issue was before I bought the car and I already drove it for more than 4 days up to 60 miles, but the Aux battery connector looks white from salt maybe need to be cleaned to allow car to charge it.
What do you suggest to clean the connectors.
If didn't work so the battery need to replace as the car was stopped for whole 2022 year until imported to Lebanon.
BEFORE CLEANING...
Make sure you're using the right genuine battery and not some random motorcraft replacement. Specifically AUX needs an external venting port.
How to clean... some ppl use baking soda. Auto part stores sell protective spray... cleaning strategies are not my strong suite.
BEFORE CLEANING...
Tomorrow morning I will check it and try to clean.Hope it will work.
Thanks again.
Some of them have venting hose, so make sure it is connected and venting outside.
Driving without aux battery might trigger whole list of codes. Unless desperate, I would avoid it.
Thanks in advance.
Thanks in advance.
My old one, I charged overnight and it was 12.4V outside of the car, and if I drove it for 30min it will trigger the message. It was tested, and it was 30% health-wise, real CCA/nominal CCA. Replaced it with a new one, and I have not seen the message for a long time.
I check the HOLD feature it is working fine but still ECO is yellow but I did short trip for 5 miles not more maybe I need to move for more mileage to satisfy all parameters.
Can I use HOLD and Start/Stop at the same time or not for example at traffic light stop can I use HOLD feature instead of ECO start/start without disabling ECO from dash panel.
I have/had 3 cars with the feature and only 1 was very predictable how it works. My present W212, driven few days apart need about 10 miles before ECO will start working. I wonder if that is the battery (2 yo) needing charge, or AC in 90F weather.
On my GLE, when I bought it, ECO would not work at all for a year, till I replaced battery. Now it works, but only for 30 seconds, when our red lights have a minute long schedule.
But now no errors on dashboard and hold feature is working as it is so for me ECO not required as most of my trip is short trip with total 100~150 miles a week or 2 week.
I will test it when I go highway and then move to a city at traffic lights ( away from my home around 20 miles) in the coming weeks.
The underlaying causes are poor alternator management by the engine control module.
A normally working W212 turns on "ECO" available flag under 10mn and keeps operating stops after stops under 3mn max.
Instead of trying to fix a busted ECO system, enjoy that you don't need to disable it.
To simplify what's what:
AUX ---> HOLD
MAIN ---> ECO
AUX + MAIN get charged together by the amazing alternator through one-way curcuits.
When MAIN gets abused, so does AUX.
Sometimes, it automatically turns ECO off on its own even without my interference (without pressing that rectangular button to turn it off ) .I must admit it saves me from hassling thru that process
Sometimes, I see a notification the gauge cluster saying " energy saving mode activated" I don't know what it means
Sometimes, it automatically switch on the ECO mode even after turning it off by itself
My diesels don't display ECO in different color, when it is activated. When the dash light is always the same, ECO sometimes work, sometimes not.
We are driving 5 miles to the freeway, with lot of lights, who can stay for couple of minutes. Not having ECO working in such time gets annoying.
I even made a battery cable with plug in front grille, to keep the battery fully charged in days when we don't drive. That helps, but not always.
I drive with monitoring scanners, but they don't show ECO features. The one that does is laptop based, so not easy to carry on the road.
On the E (now sold) who was more predictable, I would come to stop on freeway exit red light, wait 10 seconds and move 2 inches, when ECO would kick in. The ECO when works will engage for several stops & goes we do during heavy traffic at red lights.
Than when battery gets low, the engine will restart , when you hold the brake. Scared me pretty hard the 1st time.
Today I had a trip for 100 miles(Both directions), when start at cold and during the first 14 miles the ECO light was yellow until I achieve the gas station when I stopped the engine after filling the tanks and start the Engine and moved, the ECO light turn green the whole trip. Afternoon when getting back to home after 2 to 4 miles the ECO light turn green and keep until get home. So I guess it is working as expected maybe it need sometime to enable the first time in the same day specially moving above some miles.
I would guess your charging voltage management is likely still functional at this point.
Try to keep main battery on a CTEK FLOAT charger during extended parking periods of more than 3-5 days.
Enjoy,
I've recharged main battery to "floating" -- it recharges Aux. Battery, too, yes? -- then used the IcarSoft 3.0 to run codes. Got a CGW[ZGW] Central Gateway fault. I reset this code successfully, and the Malfunction Message goes away and Stop "Hold" resumes working. Unfortunately, the message returns after one drive cycle. (One drive was 4 miles, and the last drive cycle was 24 miles in length.)
I haven't tried charging the Aux. Battery separately. I assume to do this that I remove the battery, but I am reluctant to do this, for some reason...
So, should I go ahead and buy a replacement Aux Battery and hope that solves it?
FCPEuro price ($160) is $10 higher than the MB Dealer, LOL.
I'm tempted to try Krzysztof's suggested Amazon Battery noted in Post #6 above.
Any suggestions?
