Seat belt retraction?
Yes, another question as I remember things I notice. My driver's seat belt is very slow to retract (2011 E350 CDI w/ 170,000 kms). It will retract by itself, but it does take a while. It is quite easy for me to help it along, but I don't think I should have to do that. It is not dirty, so I don't think anything is interferring with it. Any thoughts about this?
Thanks,
Glenn
First is grimy dirt in the turn buckle (aka D-ring). This is the device that the seat belt webbing comes out of, to the left and above the driver's shoulder. Pull out the seat belt webbing enough to lift it above the turn buckle, and inspect for grime. Thoroughly clean it up with interior cleaner.
Another is dirty seat belt webbing. If the seat belt webbing is dirty, it can get stiff, and it doesn't take up onto the seat belt retractor spool very well. Just clean the seat belt webbing. I recommend using a solution of warm water and Woolite. Put the cleaning solution in a bowl or small tub, that will fit on the driver's seat. Pull all the seat belt webbing out, and clamp the seat belt webbing up by the turn buckle, so it can't retract. Put all the webbing in the cleaning solution and let it soak for a while. Then scrub it with a soft brush. Once clean, replace the Woolite solution with warm water and rinse the cleaner from the webbing. Next, pat the webbing dry with a towel. Let the webbing thoroughly air dry before letting it retract. This may take overnight.
Lastly, the grease on spring, for the retractor webbing spool, gets thick over time. It is a lot of work to pull a seat belt retractor. And it takes quite a bit of careful work to open the spring cassette without having the spring pop out and uncoil all over the place on you. When I was working in a seat belt manufacturing facility, I did this hundreds of times. But I also had a few springs get away from me. I wouldn't recommend it for the inexperienced. If the spring pops out, it is all but impossible to reassemble, and at that point, you will need a new seat belt. So if the first two items don't remedy your slow seat belt retraction, you either have to live with it or get a new seat belt.
https://www.safetyrestore.com/conten...epair-services
I did not know that there were seat belt repair services available. That looks like a great option, if the cleaning methods don't do the trick.
It seems to me that the grease shouldn't be interferring with the operation after only 11 years or it would be all over the internet about MB's terrible seat belts. More likely to be dust or dirty seat belt webbing, I think, given the possible causes. Only 171,000 kms, but mostly city driving. I'd expect lots of seat belt cycles, so I'll predict dirty seat belt webbing.
Can't get Woolite here. Do you think any other standard laundry detergent will do the trick?
Thanks,
Glenn
Thanks,
Glenn
