100K Maintenance (2014 E550, 4.6TT - 4.7TT, M278, W212)
-Camshaft solenoids (4x) and position sensors (4x) along with the sacrificial harnesses (8x)
-Spark plugs and coils (not sure if this was ever done, I don't see it in the maintenance records)
-Transmission fluid flush/replacement (also not sure if this was ever done, I don't see it in the maintenance records)
-Engine filter swap (2x)
-Cabin filter swap (1x)
-Clean and lubricate pano roof
With that, are there any other things that are jumping out to peeps? Like "you gotta do the..." as well? Again, this is all preventative. My car is running great right now and I want to keep it that way!
You have pretty good bet on MM, when transmission mount usually last much longer.
Add clay/wax job. The car deserves it.
Making the exterior like new will be my next task after all this stuff. Cars paint is in fantastic condition so it just needs a little love!
You also don't need a fancy fluid extractor/pump like a Mityvac 7201 or the alternative to do the service it's actually an incredible pain in the *** to do it this way. I've bought 3 and all the seals fail and I HATE them for it, so I just use a $10 Slippery Pete handpump and 722.9 ATF adapter off amazon. You will drain something like 4.5 liters, buy six for insurance or to do a little 1 liter flush later. The 7L fill assumes youre going to drain the TC which is more trouble than it's worth for 99% of people. You can do this for the same difficulty as an oil change honestly and I bill $550 for the service. Buy two sets of bolts in case the gasket rolls so you don't re-use a stretched bolt, Elring or Corteco make the good ones for this application.
For the cabin filter use either the Hengst Biofunctional, or the Mahle Caremetix biofunctional. I loathe the Mann carbon/biofunctional ones because they come with a replacement clip that NEVER fits. Filtration is good but not as good as the others I mentioned too. The Mann or Hengst filters are the best. I use Hengst for the tight seal, plastic top, and white cap o-ring.
As for plugs/coils you can get by honestly just inspecting them and checking their gap and if they're eroding at an angle or something. Most coils won't malfunction without throwing a code or giving you a lumpy idle, but it's not really a service interval thing for me unless the car is like 15 years old. You can inspect and replace the boots and springs on them though they get a lil baked from the heat. The double platinum recommendation of being changed every 60k is a BIT conservative, I keep having to replace new looking plugs for $600+ at the shop and I feel bad. I have a pile of Bosch/NGK double plats for my car for a long time.
I don't want to sound cheap but the solenoids/magnets and pigtail harness is a bit much if you don't notice anything. I completely acknowledge that it's a thing, but but but if your magnets are in good order just inspect your engine with a mirror every now and then. You'll also smell oil.
I'm more of an inspect and diagnose guy, it tends to stave off resentment towards a car for it's upkeep costs if you can spread it out and do things as they're needed instead of some arbitrary service interval. If I did every single control arm at the recommended 100k I would have missed out on like 40k of completely perfect driving for example, and I have a blank check for parts, I just find fixing my own cars instead of customers' cars a huge drag.
As for the sunroof, YES not enough people do this. MB has a stupid spray thats bespoke for specifically that job, the 3M silicone spray works in a pinch. I would also check your drains make sure you're good.
I bought my E550 at around this mileage, you just gotta do your filters, smell for oil/coolant leaks. They're particular about battery health, so every 3 years about, change the battery on your remote if you need stuff to do, always good.
Oh yeah Maxlife is a hoot. I think it says it works in both 236.14 and 236.15 but if you look at the spec sheets for the particular fluid, they both say don't mix the two fluids. Yet we have a fluid that's suitable for both specs according to the maker of the fluid even though both specs say not to mix it. Needless to say Maxlife isn't on the approved list for either spec although Vavoline does have fluids on MB's approved list although you never see them in the stores, you just see Maxlife which is one size fits most. Still it seems to work ok, people do use it.
https://www.shell.us/business-custom...r-locator.html
DAMN the shell stuff is VERY reasonable! If I wasn't an AMS dealer or had same-day access to Febi through Worldpac I'd stock this FOR SURE over using the dealer stuff. It's $7/liter, shipping is $25 which is a little brutal.
