Comand Issues
Your NTG works but the HK Audio has no sound with a known good Amplifier. Engineering screen shows a "Ring break pos.1" and "Wrong MOST-Ring".
Your issue is an open fiber link in POS.1.
No light > no data > no digital audio sound!
Now the whole question becomes...
what is the module sitting as MOST#1 ??
That module is sleeping not passing any data out. It is keeping your fiber loop open.
This where @konigstiger pops the best document with all the answers
I think somewhere around the NTG Menus... you can display the ordered list of active MOST devices... get that list of devices!
The missing module will be your bad guy... satellite module (trunk left side) + 3G Cellular module likes attention (trunk forward)... double check.
> BYPASS Workaround... $5 Fix:
If a useless module is raining on your parade, chances are you can bypass it with an eBay fiber extension .
Last edited by CaliBenzDriver; Apr 5, 2023 at 09:42 PM. Reason: KT Docs / Bypass plugin
In the TRUNK you have:
- Satellite module (driver side)
- main Ampifier module (near sat.)
- bass channel Amplifier (under rear deck )
- MBrace module (over gas tank)
- NTG upfront head
- (Aux input option module?)
