Normal temperature ranges
I have recently join the MB club and purchased a used 2016 (W212) E550 (M278) 4matic and had several questions. I noticed the temperature gauge to be sitting between the 90C and 100c as I know that the temp should be between 80C - 90C, however when checking my obd reading it would show the engine coolant temp when ideling (after somewhat a rough drive and 8c outside) to be between 95C -105C. Now would that be normal for this M278? I attaches a picture of where the gauge is. 136K on it and coolant is full. Thanks!!
Different engines, have different thermostat settings, but most of them open in 80's C.
100 is slight overheating, so check your whole system
If you want piece of mind get a scanner.
Worth reading
This is how the thermal management is set by MB for the electric heater assist thermostat
https://mbworld.org/forums/e-class-w...mperature.html
Excellent stuff is buried all over this forum... not easy even for anyone of us to find precious info.
What do you think: useful or useless to create LINK INDEX??
The section was very fortunate to have highly-educated members, who have done excellent work. Bad part, everybody is moving ahead sooner or later and new owners of aging MB present different level.
Yes, this is it !!!
That's what I am talking about, thank you Kajtek for sharing this example.
I have created a link for this W210 power users...
A header post with an index of links pointing to key threads plus the key threads where the content is developed.
Individual can elect to index all sorts of things they are interested in .... wheels, airmatic, tuneups, modules, fixes...
Keeping things disorganized is a giant waste of ressources.
I am going to try and read what the old timers were dealing with W210 chassis 25 years ago.
I prefer curmudgeon, but old fart fits.
great work you guys, I plan on keeping my '12 for at least ten more years, just turned 32k miles and if I can get to the desert soon, I know it will make it, so I will be looking back on all this awesome work on the 212 encyclopedia for quite some time, My '13 is about to turn 90k miles this summer and has been in the salt for ten years now, I went and saw the '23 E and it's really nice, much nicer than the 213, so we'll see...
What year they start?
Would they be available in US with OM654 diesel, I would start saving money.
I am still missing hood star on it.
M111 - 1992->2003 (11 years run)
M271 - 2002->2015 (13 years run)
M274 - 2011-> Present (12 year run) and a piece of junk with wrist pin issue, broken piston, etc. Lawsuit in progress.
M264 - 2018-> Present (6 years run) transition engine towards electrification from M274->M254->xxx. Casually came out around when all the issues of the M274 started to pop up worldwide.
M254 - 2020 -> Present (3 years run) includes electrification with a 48V battery. Hope you have read the horror stories with the initial 48V vehicles.
It seems to me MB is sending out technology-in-progress engines, and customers are their QA department and supporting ($$$) the transition. Would we be able to find parts for the engine with a short run? Will the independent be able to learn enough on how to fix these engines since there will not be many of them out there.
I would stick for the established V6/V8 generations, though not perfect until the recent versions stabilize a bit more.
*** Updated *** to be fair with the diesel engines .
I owned./Own 1 to 4, Shall I shoot for 5 ?
The W123 and W124 was at the time classify as 300 class, before MB come with letters for body description
Actually last years of W124 were called E class, so that would be the 1st
