Sponsored by: CARiD
Front sway bar bushings replacement - Help
Old May 15, 2023 | 06:17 PM
jayalaba's Avatar
2006 E350
Stuck as a picture. Remove the sway bar and needs to replaced the bushings. Not able to detach the metal clamps. Please guide.
Old May 16, 2023 | 02:42 AM
S-Prihadi's Avatar
The bushing are "casted/moulded" into the sway bar and can not be replaced on its own.
You need to buy complete sway bar.
I know its kinda sucks, but that is how it is designed.
Old May 16, 2023 | 05:05 AM
MeltdownSpectre's Avatar
2013 E250 CGI (M271 EVO)
Originally Posted by S-Prihadi
You need to buy complete sway bar..
Which MB doesn't have in stock anywhere around the world....
Old May 16, 2023 | 10:33 PM
Quint22's Avatar
Veteran: Navy
2014 Cummins, 2014 E250 Bluetec
Im sure thats how they intended it but I would also if the bushing inserts are available get those, finagle that tab open part way and replace bushing, tap the tab back into position. It wont be easy per say.
Those bushings I very highly doubt are molded in place but then again anything is possible. The retainer portion is not molded in place but crimped on after the fact. If you can find a insert that works it can be done. Maybe see if Konigstiger and see what the parts numbers are.
Old May 16, 2023 | 10:55 PM
jayalaba's Avatar
2006 E350
You are correct brother. I just hit the edges and came off into two pieces. Easy to replace and put the two parts back.
Old May 16, 2023 | 11:02 PM
jayalaba's Avatar
2006 E350
Old May 30, 2023 | 04:18 PM
cward2's Avatar
2016 GTS; 2019 Alltrack; 1974 C10; 97 993 ---- Gone GLA45, APR STG3 Golf R, 2 E55's, E63S, 911's
Where were you able to find the bushings? I'm down for the same issue! Thanks
Old May 30, 2023 | 04:23 PM
jayalaba's Avatar
2006 E350
Please try on Amazon and search like this.
Front Stabilizer Bushing, 2pcs Front Stabilizer Bushing 25mm for E Class W212 09-16 2123230965
Old May 30, 2023 | 04:43 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
Interesting find, Similarly on Ebay (as usual careful with cheapo parts) https://www.ebay.com/itm/304694803354
Also, part number 212 323 0965 is for the torsion bar, not the bushings. I could not find the bushing in the EPC.
It would be great to know if it matches another manufacturer's part number for an equivalent OEM provider.
Old May 30, 2023 | 05:01 PM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
Them boys are vulcanized on which is a heating/chemical process that makes it malleable and soft so the rubber should be at an exact fit and texture to work. You can cut the old bushings out and go the janky route with something like this:
I do not recommend this route, I've never tried it, I just know it exists.
Amazon Amazon
The correct route is something like this guy:
https://mbparts.mbusa.com/oem-parts/...bC12OC1nYXM%3D
Make sure to enter your VIN on checkout so the clerk can finalize and confirm your fitment. I got it wrong on my personal car because there are like six choices and it's pretty confusing.
Old May 31, 2023 | 05:01 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Do it once.... dot it all
It's almost guaranteed the torsion bar in question has different diameter based on "Comfort vs. Sport" trim, right?
The stabilizer torsion-spring bar is one of the early maintenance item for suspensions....
When the plastic links get wasted, additional freeplay sets in with lack of biasing forces.
I just got done dealing with exactly that 6 month ago on my daily driver: bushings + links front & back.
The rear axle stabilizer has similar parts: BUSHINGS + LINKS and maintenance schedule.
Comfort/Sport Refresher kit would be (8pcs) :
Front : Stabilizer (BUSHINGS)
Front : Stabilizer (LINKS)
/Rear : Stabilizer (BUSHINGS)
/Rear : Stabilizer (LINKS)
The more we respect speed bumps, the less these parts get abused by a lot of bumping energy.
Old Jun 1, 2023 | 05:57 AM
Bushing won't show in EPC because MB doesn't sell the bushings separately. When they crack, MB expects you to replace the entire sway bar instead.
Yes. I have seen W212 sway bars that are available with diameter of 19mm, 25mm, 26mm and 26.5mm.
There are different sway bars for RWD vs 4MATIC, Hydraulic PS vs Electric PS, Coupe/Cabrio vs Sedan, Standard vs Sport Suspension etc. I found several different part numbers online for sway bars, so EPC is always the best way to confirm.
Old Oct 6, 2023 | 10:48 AM
oldtaxidriver's Avatar
mercedes e class w212
Was it easy to replace the rubber?
Old Oct 6, 2023 | 10:17 PM
Rickman30's Avatar
Veteran: Navy
2014 Mercedes-Benz E350
While in the process, put some quality silicone grease between bushing and sway bar, saves on creaking noises in the winter.
Old Oct 8, 2023 | 12:14 AM
gashouse's Avatar
300ce
Amazon
