Sponsored by: CARiD
Will W213 wheels fit on a W212
Old May 16, 2023 | 12:04 AM
Seaniekav's Avatar
E class 250
Hello everyone I’m new to the forum and looking forward to getting chatting to you all. I’m looking to change the wheels on my 2012 E 250 and I was looking at a set off a 2014 C class. Will these fit ok is my only concern. Thanks in advance.
W213 wheels.
Old May 16, 2023 | 01:50 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Check inside the rim for molded measurements, with ET being crucial here.
Old May 16, 2023 | 05:51 PM
Seaniekav's Avatar
E class 250
That’s the info.
Old May 17, 2023 | 03:15 PM
kajtek1's Avatar
From my memory, original offset is in 40's on W212, so that should not be a problem.
This is staggered set, so you have to be careful with tire choice.
Still if you have rims already available, why not put the front one on and make double sure?
Nominal sizes are not always telling everything and you will go to 19' rims, what will not put much rubber on it.
Old May 17, 2023 | 10:09 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
Also pay close attention to the bolt length in each wheel. Too short and your wheel will fall off. Too long and the bolt will lock up the hub.
Old May 18, 2023 | 11:34 AM
4rvrDarwin's Avatar
1993 400E, 2015 E350 4matic
Don’t do 19s! They are going to ride like total crap and then some
Old May 18, 2023 | 02:54 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
W213 is the E class from 2017 forward. A 2014 C class is probably a W204.
Old May 19, 2023 | 03:12 PM
Fliplegend's Avatar
S212 E350 Estate
The W213 fronts depending on tire choice will likely rub, it's both wider and higher offset. I think you're good on the rears.
Old May 19, 2023 | 10:55 PM
ROCK1965's Avatar
18 E300, 12 E350, 08 C300
Correct. I just did my W212 with my stock 2018 W213 rims with 245/40/19's on them. The backs were okay on the rear. The fronts, I had to go 245/35/19 to not rub on the strut. Worked out perfectly.
Old May 20, 2023 | 01:57 AM
again, the OP said W213 but is actually asking about W204 2014 C class wheels.
Old May 29, 2023 | 02:57 AM
Seaniekav's Avatar
E class 250
Went for these in the end,think they suit the car nicely.
Old May 29, 2023 | 03:04 AM
BenzV12's Avatar
W212 FL
Those look nicer to me
Great choice
Old Jun 21, 2023 | 10:45 PM
Helena350's Avatar
E350
Old Jan 15, 2024 | 02:45 PM
Leajd's Avatar
W212r E class
Hello, I own a w212 facelift wagon. Its currently on 245 40 18s in summertires. I am talking with someone to buy some w213 wheels 245 45 18 inch. Will they rub on the front?
