Amsoil transmission fluid?
https://operatingfluids.mercedes-ben...heet/236.14/en
https://shop.sclubricants.com/pub/me...-datasheet.pdf
https://shell-livedocs.com/data/publ...88f7a72a9a.pdf
As soon as pump working gaps increase the pressure loss will follow. "Easily lost pressure" is what spells short lived performance.
To boost old tranny pressure: substitute 1 or 2 or 3 quarts of the non-FE blend. It helps make up for looses.
If we're talking transmission fluid, there's 236.14 and 236.15 which is ATF 134 and ATF 134 FE. They both say not to mix it. But maxlife which is not on the approved list says it's good for both applications. It's one thing to have a great spec sheet, it's another to have real world results that show that the spec works well in your application. You're kind of missing that part when you use something that's not on the approved list. It's all guesswork and theory.
The regular stuff goes bad after 20-40k miles despite having a 60k interval, nobody I know does the torque converter drain including my Mercedes dealership unless you give them a very hard time about it and show them the service bulletin that specifically tells them to do it. The cars are just hard on the fluid, but the transmissions themselves are GREAT.
The fluid works very well so far on 722.9, the AMG transmissions, and whatnot.
The first time I did a drain/fill we kept my old trans fluid in case the performance was worse. I cannot tell you how it holds up over time but the product literature says it goes farther than the normal drain interval so it sounds like they're trying to suggest it's a one-and-done.
FE refers to fuel efficient, aka these low viscosity ATF's that have been hitting the streets, Toyota/MB/Audi/GM/Porsche/Ford/VW all have one. They're thinner for minimal fuel savings but they degrade faster in my experience.
Uh regarding the approvals thing, basically Amsoil is always fiddling with the formula from what I understand, and each one needs a new approval process, and so on. Those Supertech and Amazon european oils aren't on the approved list and trust me, they're more than fine on these cars.
Now I don't RECOMMEND everybody just jump ship and start experimenting with fluids Mercedes does not want you putting in the car, but in my experience they've been good and have lived up to their claims.
I do have education about oils, but when I got fed with all sale pitches and BS about oils, I used different oil brand for each change and send samples to the lab. That was on my Ford Truck diesel and surprisingly the dino Rotella come to the top of 6 oils I tested.
So Rotella was what I was using for older cars.
Now, driving Bluetec I am aware that they can be very sensitive to oil generation as several of them seized under dealer care. What turned out, the most likely scenario was dealer saving money on newest generation oils and used older generation oil they had in drums.
Amsoil sells the product by brainwashing the customers. They might have some good products, but I don't support such sale tactics as principle.
For other fluids, I usually need them once in the period of ownership, so not much possibility to test them. I just buy them at dealer or following MB list.
Amsoil is in the research and wholesale business of train load of industrial oils. They may well have the best true gas based oil formula, what we do with cars is none of their priorities.
The additive packages is where automotive oil competitors try to differentiate themselves. Same misterious additive mix in different percentage. I can guess the most additive in the best stock oil base is the best oil... that would be the Penn Ultra-Plat.
The engine rubber supplier has a formulation resistant to heat but sensitive to acidity ie. dont let your fluids become too accidic (calcium additive protection against accidity)....
Diesel vs. Petrol engine protection:
Diesel oil can offer superior protection for lack of requirements to prevent contamination of platinum catalytic filters.
We know our petrol engine can burn a lot of their own crankcase oil. This directly degrade lambda and cat converters.
So an oil with super high lubricant package can benefit friction but hurt mufflers.
Which oil is best to use... likely the most compatible with OEM specs.
Thanks for the info gang. I think I am going to give it a try and see what it does. But have to talk to my shop first to make sure they can drain the torque converter too on mine without it costing an arm and a leg.
Chassis has commented before about the clutch plates, especially that 4th gear. I am mostly curious if switching the trans fluid brand itself would make an improvement here. Guess there is only one way to find out. I do know my car runs smooth at butter when the temps outside are below 90. Once it gets summer time hot though, it does shift a little lumpy, I get that "skip" feeling, almost like a misfire, but no fault codes ever thrown or stored.
I am also going to have the PCV replaced finally too. I know I have a small trace of oil getting into the intake and all fingers seem to point to the PCV needed to be replaced.
So no, I have not, but I will. If I don't care about the car then I'd buy cheapo Ford fluid. I use Ford fluid in my GM, because it works better
I collected full 5 qt of old fluid, what will make good exchange ratio.
Magnets had nice puddle on them, so I wonder if that might be the 1st service in car 150k miles life.
Interestingly, Sr Leigh was not as accommodating/patient with the drain plug and resort it to creativity
Does anyone know which 722.9 have or do not have the drain plug? Is it based on specific platforms? or years? I read that only the early version 722.9 on the S-Class (guinea pig) does not have the TC drain plug,
Some documents from other threads:
https://mbworld.org/forums/attachmen...-converter.pdf
From the documentation master, @konigstiger
https://mbworld.org/forums/e-class-w...ml#post7364264
My transmission code from my data sheet is 722960 07 754738. What does this mean? I haven't a clue. The card also notes: "A63" - FE Torque Converter Housing-0, and "A64" - FE Torque Converter 0 MM. Also has "A89" - Reduced Friction, which I believe is when the "blue" transmission fluid instead of the red comes into play.
I have thought about taking some of this on myself, I have turned more than a few wrenches in my time. Totally rebuilt all suspension components, removed and cleaned a few solenoid screens, plugs, fluids, cleaned out a few intakes and butterflies. But honestly, doing that all again at 50 years old and for a car that isn't "my toy", getting on the ground and sliding around underneath, really just doesn't ring as exciting to me as it once did long ago. Wish it did to be honest.
There always is a story behind a procedure. I go through these "I know better than the previous engineer that was here" every week, and I have to wait until they come around with "Ohh, I never thought about xxx, and yyy" or myself with "very clever approach, and it takes care of the previous requirements as well". It works both ways.
Note: last week friendly talking to a Senior Engineer at a turbo manufacturer about oils (because this thread and others related to turbos), he emphatically said that if I did not care much about MPG, to raise engine oil from 0W-40 to 10W-40 if listed in the manual. His recommendation for longer turbo life was:
1 - 10W-40 if listed in the manual, screw 0W and 5W
2 - DO NOT ever step on the gas of a turbo engine that is still cold unless I wanted the turbine side impeller to rub against the housing. Let it reach operating temperature; otherwise, the housing has not expanded yet
3 - DO NOT ever turn off the engine after an Italian tuneup w/o letting it sit, or driving it soft to let it homogenize/uniformly heated/cooled all around.
He said, "you do that and the turbo may outlast the car". That is how confident they are in their designs. He mentioned the 0W-40 was too thin for the turbo shaft bearings, and theirs are tested vs 10W-40 and proven to last longer.
Food for thought.
$9 for OE
Signature is typically if you're super hard on your vehicles beyond their design limits like a truck towing heavy for a long while and the temps get way up there, you can destroy an ATF fill on one particularly gruelling cross country trip fully loaded. The OE is for everybody else. You should just check your drained fluid and evaluate for yourself when your intervals are.
25% off link, nobody should pay full price.
https://www.amsoil.com/offers/pc/?zo=7236674
Amsoil Signature Series FE ATF
https://www.amsoil.com/p/signature-s...tl/?zo=7236674
Amsoil OE FE ATF (normal stuff, probably works fine)
https://www.amsoil.com/p/oe-fuel-eff...tl/?zo=7236674
Bilstein ATF 134 FE I've been using for a LONG time for years between different cars the AMG GT-S was on it before I switched. The Liquimoly 1600 Top Tec which is absurdly expensive at $16/L and neither are approved by BEVO and I would bet my houseyou would have a good long life using either of these. I usually recommend 7L for said flushing technique. But 25L is more than welcome if you wanna pay for it
The G, GLK, GLE are particularly hard on ATF due to the weight, so honestly with all the "why my does my transmission blah blah" threads on here I'm surprised people aren't drawing conclusions to the OEM fluid having a much shorter interval than advertised! I'm well aware it says 60k but no way in hell across 3 different vehicles have I ever gotten remotely that far with a fresh drain and fill.
Youtube of me showing what Pentosin ATF134FE typically looks like after 20k, I'm hard on the cars, idle them in the summer, etc. This is the approved correct fluid, 4.5L out, 5L in, 2 more L behind it to chase out some of the old stuff it felt gross driving beforehand like this with tons of shudder when it was hot, it would lurch in the mornings til it warmed up til it started shuddering in the heat of the day. all my vehicles this day. Please excuse the music I'm still a kid at heart.
https://www.youtube.com/shorts/h2u0rPqFQFM
PS I will mirror what a couple people have said, DO NOT let them use a flushing machine, it flushes stuff UPSTREAM from the filter into the transmission where it would never go, and it usually drains out through a transmission line from the radiator from what I understand. You can also blow out gaskets which have spent their entire life functioning one-way and suddenly having fluid reversing isn't great. Shops tend to have a machine they got conned into buying because it would "increase profits" that they're itching to use like a brake rotor or flywheel lathe but I would adhere somewhat to the accepted procedure of either doing a partial 5 out of 7L drain and fill, maybe do it again in a year if you notice shuddering, or put 5L in, and introduce a little bit at a time and let the extra drain out across an extra L or two to be really sure. It looks great after this.
I'm happy you purchased 25L but for environmental reasons I just feel bad that so much fantastic ATF that would otherwise last you many drain and fills would get recycled for the sake of OCD.
I understand the 25 quart thing, but I would simply be physically unable to do that. I was telling someone the other day; I am physically capable of cutting off my fruit basket, yet it is impossible :p
OH I should show you guys the best setup.. so most people have some contrived setup from a converted chemical sprayer for doing ATF fills, it's REALLY not that hard. So after you fill it, just overfill it by half a quart at a time, let it come back out til it dribbles, repeat, run a couple quarts extra and you're pretty clean afterwards. If you use this handpump it transfer a crapton of fluid quickly and efficiently, no fatigue at all it's actually ergonomically correct too. For filters just buy the kits VAICO sells with the bolts filter gasket magnets fill tube, buy two extra bolts just in case, and you're gonna be totally fine.
25% off Amsoil
It'll thread directly onto the Amsoil bottles, trim the plastic fill tube so it hits as close to the bottom. The Mityvac 7201 that most people are recommended is an absolute piece of ****. I cannot get them to last six months of professional use. When you look at one it's literally just held together with hot glue and they lose pressure over time from blowing out their own seals. I know how to keep these maintained I clean and wash them and don't store fluids in them ever. I would rather you guys use these handpumps and rinse them under the sink than go through the trouble of dragging a stupid tank around with its stupid leaky tubes splashing every where. It's not even very good for oil extraction oil changes because you have to stand there to keep pumping it, vs you can just undo the plug and walk away and have a smoke/beer. It's 30 minutes to extract the oil and you still have to transfer it back into the container to recycle anyway and for me I have an oil caddy which is already super convenient and I burn it for heat in winter.
