Amsoil transmission fluid?
Every device is different with custom specifications for each. Unless you know which specifications your transmission requires, you are best just buying from the dealer with your VIN number.
Summary: there is no answer to such a wide-open question
For MB vehicles, they have this website https://operatingfluids.mercedes-ben...heet/236.21/en
I personally used Amsoil oil for the engine and transmission of an old Toyota Camry back in 2016 with @200+K miles, and though it seemed ok the first few days, I would not use it again unless I am forced to. Way too many other options to invite trouble. Just my 2c.
I’m curious if it helped to make it even smoother.
Long ago I bought a Mazda 3GT sedan. Wasn’t long before I replaced the trans fluid with an approved Mobile1 fluid, and it made a tremendous difference in smoothness, sound and feel. Was just curious if anyone’s tried it on the benz.
normally I am 100% in favor of genuine OE trans
fluid. Still am mostly.
and, even with the best data available existed. What is the saving vs risk associated with a change from an established process? Just a quick example: A fleet of 100 vehicles x 200 miles/day x 30 days/month = 6000K miles/month/vehicle @ 5 qts/vehicle (to use round number) -> 500 qts/months x @$10/quart x12month/year-> $60 000/year for oil. Say, a cheaper provider gives a 10% discount, i.e. $6000/year. You only need one engine to fail to lose the advantage or saving. That is, 1% failure rate and everything is gone. IF, a big if, it is not a good as the "true and tested oil" (whichever that may already be) the fleet is in the RED.
In my book, I am extremely conservative to changes that produce minimal gains against established processes. Summary: if it IS working, DO NOT fix it.
And, on experimenting with expensive toys, my hard-earned money I spent on other pleasures than second-guessing my engineering colleagues. The companies they work for have deeper pockets than mine.
https://www.shell.us/business-custom...r-locator.html
again, I am just curious if anyone has ever tried this stuff in a benz? And if so, was it good, bad, blah, etc?
i use amsoil and only amsoil . For many years. My 1k hp m157 only uses 5w 50 signature series . Mobil one does not have the film strength that I require for protection . Mobil one burns often and requires top offs where as the amsoil does not require nearly the same amount . Amsoil is actually one of the best oils made . And you can actually search black stone labs and research other oil analysis based off amsoil. Now when I say one of the best I'm not saying it is the best . But it definitely deserves the total as one of the best. As far as the trans fluid I use amsoil ATF fuel efficient. I haven't had any issues . And it works perfectly fine . Do not use atf multi vehicle . The viscosity if to thick for the 722.9
If the specs of the oil or trans fluid or gear oil line up with what your using it for IMHO its gonna work fine. In these threads however your going to have opinions based on other opinions, opinions based on experience, opinions based on perceived experience, opnions based on monetary propoganda, opinions based on everyone has one.......
Personally if I had to change the fluid more than 50k miles I would probably look into it and figure out if there was actually a better alternative however from what I have read if the fluid is changed often enough there arent issues related to the fluid. I have no qualms about straying from the PAID FOR recommended list of any manufacturer.
If we're talking transmission fluid, there's 236.14 and 236.15 which is ATF 134 and ATF 134 FE. They both say not to mix it. But maxlife which is not on the approved list says it's good for both applications. It's one thing to have a great spec sheet, it's another to have real world results that show that the spec works well in your application. You're kind of missing that part when you use something that's not on the approved list. It's all guesswork and theory.
MB 236.15 --> ATF 134 FE
I may play the lotto this weekend, and if I win I will start researching using canola oil instead, any recommendations on which brand of canola oil is best for engine or transmission,
In MB, it means final edition, in technology it sometimes mean fan edition but what does it mean in this case.
Unless FE means absolutely nothing they just want to distinguish it.
