Oil change using Fluid (oil) extractor versus not
Received 1,751 Likes
2016 E350 Sport
kajtek1 (06-02-2023)
2014 E350 Sport 4Matic Sedan
I failed to explain the benefits of the Mercedes oil extractor adapter, that I provided a link to above.
Remove the dip stick and insert the adapter in the top of the dip stick tube. Then insert a hose from your extractor that will friction fit in the end of the adapter. Then start sucking oil. The dip stick tube acts as the tube, down into the bottom of the oil pan. This works super slick. You will get all the oil out, with little to no mess, and very little effort.
DO NOT try to push a plastic tube down the dip stick tube to extract oil. This method has very frustrating disadvantages. It is messy. It is difficult to find the right depth to press the tube down the dip stick tube, partly because of obstructions that the tube will hit. And because of the previous item, it is difficult to get all the oil extracted.
I always do oil extraction with the car flat on the ground. There is no need to put it on ramps, or tilt the car with one wheel up in the air. Using the method above, you can extract almost all the oil that would come out of the drain plug. Above, I said that it is within <4 oz. But I checked my notes, and it was between 2 and 3 oz. that I captured, when changing my oil using the extraction method above, and then pulling the oil pan plug, to see how much oil remained.
Thanks for the link. I watched the video on the OEMTools extractor, and it looks like it is much better designed than my Mityvac 7400. I like the quick connects for the hoses, and I like the tube stowage location. I saw that there is a pneumatic version of the OEMTools, and it is only another $9. I also like how the pneumatic version also has the manual pump feature, so it can be used either way. I think I'll be replacing my Mityvac with an OEMTools.
FYI this is the extractor I bought https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1
Not sure how it compares to the other ones but it seems to work great for my application (knocks on wood). Like has been mentioned the only time ya run into trouble is if its cold oil. I tried it one time was like 35F outside and took about 45 minutes but still did it. I had forgotten to warm up the car before hand and learned my lesson.
Quint22 (06-02-2023)
Received 1,736 Likes
1922 Ford Model T / no OBD
The dealer will not do $100 CV joint boots, charging you $2000 for whole axle, they will do ATF drain, without letting it drip, so less than 50% fluid change.
I can write whole book of those samples.
The following 3 users liked this post by kajtek1:
2016 E350 Sport
Each time I use my extractor, I measure (and mark) the amount of oil sucked into the extractor column... Thank goodness you can see the oil through the cylinder. Comparing the measured amount of oil with the amount of new oil installed, I rarely see more than a pencil lead thickness of difference in the removed column of waste oil. This miniscule difference is easily accounted for with minor oil burn, any evaporation, etc.
So, I am 100% certain that I am performing the oil extraction per the book, getting 99.8% of the oil out, without tilting the car to one side, or hopping on one leg, or standing on my head, or facing East and asking MB for forgiveness in doing the work myself.
2010 E350 4Matic
I think it is way more pain to drop the bottom cover than any "trouble" with the Mityvac. I have used it since I bought my car in 2012. I have 186000 miles on the clock and have changed oil every 5000 miles. The first 5 years the dealer changed oil at every 10 000 miles, but I changed myself between at 5000 miles. Dealer changed oil as my car was under the extended warranty and I chose to let them do it in case something happened to the engine, and they cannot blame me for not changing oil for it...
So my car has seen well over 30 oil changes and just about 30 of them with the MityVac without any issues at all. Mine is the bigger one that takes the whole 9 qt. of oil in it. Super easy job if you remember to warm up the engine first. If oil is cold, it will take some time to extract using the skinny tube, but hot oil comes out is about 5 minutes. Then it goes just as easy in the empty oil jugs to take to recycle.
You will never extract 100% of oil and my estimate is that at least a cup (if not 2) are trapped in engine valleys.
But some owners are very picky about couple of spoons of oil that will stay in oil pan.
When I am not that picky about some oil left, putting a plank under the wheel takes just seconds, while it will avoid couple of minutes of gargling with oil extractor.
Just FYI, the oil dipstick tube has very small hole few cm above the end, to release vacuum who can be created above the scale.
So using extractor, who connects to top of dipstick tube will always create some gargling.
#32
Received 2,446 Likes
PFL205.064 with M276.823 (Oil pump solenoid defeated)
#33
#34
2016 E350 Sport
#36
I finally received the Oil Extractor (delayed shipment)... I purchased this one - same as the one @Quint22 bought. I do have a question. The tubing that they sent only one that goes in the dipstick is 4.0X6.0 mm - assuming that is ID/OD. I tested it and it is very snug pushing it in - it just does not slide in (nor will it go in at all) unless it is pushed in. Is that normal or would this be considered too tight? Whether I need a smaller diameter or not, just curious how far in it needs to be pushed in. I measured the dipstick and marked the tube. Would that be far enough in or to get all the oil out or would it need to be in further. Not sure of the shape of the oil pan relative to the dipstick. Thanks
#37
Try to make an adapter to connect the biggest extractor tube to top of dipstick tube. Using smaller tube will get really annoying.
You should feel when the smaller tube hits the pan bottom.
#39
As long as you can slide the smaller tubing in without risk of breaking, that would be good fit.
#41
2014 Cummins, 2014 E250 Bluetec
Mine goes in pretty easy, there is no real resistance until it hits bottom. Always hard to tell description thru the computer but as long as it goes in and you can tell when it hits bottom your good to go.
With the small inside tube (not the big one with adaptor) I usually warm engine some, set it up, remove oil cap, get it vaccing the oil out then start the oil filter change. Takes a few minutes but by time your done its usually not much longer and ya hear the gurgling of sucking air at the bottom.
#42
Then picky DIYer will also extract few spoons of oil that stay in oil filter housing. ..............
Filter housing is also much more convenient to fill new oil.
MBNUT1 (06-11-2023)
#43
I think I figured out a way to do what you mentioned here (connecting the larger smaller length tube to the top of the car's dipstick tube) and use the dip stick tube as the tube to extract the oil. I will hopefully try it today and if it works will post some pictures. Hopefully it will and I am curious to see how close to 6.9 quarts I get out.
#44
[QUOTE=Quint22;8794905]Mine goes in pretty easy, there is no real resistance until it hits bottom. Always hard to tell description thru the computer but as long as it goes in and you can tell when it hits bottom your good to go.
Thanks - to better describe I inserted the tube in my older Audi and it just slid in easily- I could do it with one hand without concern of it bending. Not with the Mercedes E350. To prevent it from bending you need two hands and need to feed it as close to the opening of the dipstick as possible. I will try the other method I figured out first and see how it goes.
#45
I finally received the Oil Extractor (delayed shipment)... I purchased this one https://www.amazon.com/dp/B07N7X4TP9...roduct_details - same as the one @Quint22 bought. I do have a question. The tubing that they sent only one that goes in the dipstick is 4.0X6.0 mm - assuming that is ID/OD. I tested it and it is very snug pushing it in - it just does not slide in (nor will it go in at all) unless it is pushed in. Is that normal or would this be considered too tight? Whether I need a smaller diameter or not, just curious how far in it needs to be pushed in. I measured the dipstick and marked the tube. Would that be far enough in or to get all the oil out or would it need to be in further. Not sure of the shape of the oil pan relative to the dipstick. Thanks
I highly recommend against trying to push a smaller plastic tube, down the dip stick tube. For me at least, that method yields inconsistent results in extracting all the oil. As you touch on, there is uncertainty on how far down to push the tube. It is extremely hard to judge what the right depth is. Not deep enough, you don't get all the oil. Too deep, you don't get all the oil. It is a messy method, and can be difficult, depending upon the o.d. of the plastic tube.
The adapter method is super easy. No mess. No fuss. My understanding is this is the method used by MB dealerships, as the dip stick tube is actually designed with this function in mind.
#46
Order one of these. The larger of the two hoses that came with your extractor, should fit snuggly in the large end of the adapter. The o-ring end of the adapter fits in the top of the dip stick tube. Oil will be sucked up the dip stick tube.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
#47
[QUOTE=MPTrader;8795115]
Mine works how you describe it with your audi. Interesting. Mine is a E250 so different engine than the E350.
#48
2016 E350 Sport
I still use a funnel, but the reach is shorter, allowing better control of those Walmart 5qt jugs. And, your aim needn't be so precise that way. (hehe)
Edward993 (07-16-2023)
#49
#50
2016 E350 Sport
Using a funnel to avoid spillage, the speed of oil flow is only limited by the exit of the funnel. The oil filter housing opening does not restrict oil input at all.
Bhopkins (06-13-2023)
