E350CGI Suspect overheating
I noticed yesterday that the fan came on with the coolant temp indicating 93degC which seemed too low. Is it possible that the coolant temp sensor is faulty causing the engine to run hotter than it should, thus causing the fuel to boil in the rail giving the high pressure fault?
Any ideas/help would be appreciated thanks in adavence
On my diesels I have more things to observe, so I "ask Santa" to bring me ScanGauge 3 for Christmas.
Still for occasional use, cheap dongle with Torque app will do.
I would recommend you focus on the fuel supply before suspecting uncontrolled cooling temps. Perhaps both issues are related to a poor connections.
-- Spend some time to measure the live fuel pressure sensor voltages (Input Ref., output Voltage, GND!). If the control circuit is proven good, pressure sensor may be getting marginal.
-- What type of fuel pump(s) does your 2010 V6 uses ? Single pump for low-pressure or double pumps setup for high pressure GDI?
-- Analyse circuits to condider the pressure sensor and temp sensor may both share a poor GND connection or simply clean to begin with. Locate your sensors to help locate their GND supply: engine/chassis ?
Don't be tempted to "Play Russian Roulette" with the parts canon. A thousand things can be bad so test twice and replace once.
If you don't have a decent scanner now is time to help yourself.
++++++ Pressure control:
-- I would recommend you focus on the fuel supply before suspecting uncontrolled cooling temps.
Good luck with the new coolant sensor.
