Sponsored by: CARiD
AC Compressor Conundrum?
Old Aug 14, 2023 | 01:37 PM
DBSeer's Avatar
E350 (W212)
Question AC Compressor Conundrum?
Hello my friends from MBWorld,
I've had a 2014 E350 with a broken air conditioning system for some time now. I would like to narrow down the problem with your good help. I think it's just a bad AC compressor but here is what I know if anyone wants to throw in their ideas.
- AC Compressor clutch does not engage when AC is turned on
- Low side has higher pressures (75-100 PSI)
- Radiator fan works fine
I've always seen that there can be some AC relay or fuse but I never found any in any fuse box diagram so I could never really check, information about any AC relay or fuse is appreciated.
I appreciate any information anyone has to offer and please request any info you'd like,
Old Aug 14, 2023 | 02:12 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
check clutch circuit
Test the continuity of the clutch coil... these are known to get open.
Check that voltage/GND is present at clutch circuit.
Next step use a scanner to read the status of AAC controller.
Old Aug 14, 2023 | 03:08 PM
DBSeer's Avatar
E350 (W212)
Will do, thank you.
Old Aug 14, 2023 | 04:38 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
Originally Posted by DBSeer
Will do, thank you.
If you do it with a MB-aware scanner, and the problem is the clutch, you should get something along what I described in https://mbworld.org/forums/e-class-w...ml#post8694515
@tvn858 and @Rulebraker followed some of the steps, and they also repaired their AC at a low cost, but some ^&*(@#$ words in between.
Old Aug 16, 2023 | 06:37 PM
Luddyludwick's Avatar
'11 E350 4Matic Wagon
Front SAM ok? LIterally had this issue today.
Old Aug 16, 2023 | 09:36 PM
no air 🫤
When A/C goes out is when you need a working sunroof. ✌️
Scan the car computers
​​​​​​test the compressor clutch
check voltage supply
get more ice-cream
