Chirping noise rear of bank 2
I'll try to get pictures and/or a video if it cools down today.
Now mine is not that bad, but at cold start, and it is quiet till fully warmed up.
Again, while similar, not the same because I take off my oil cap and mine continues. But the tone of it is the same. Just like a belt chirp. why I'm thinking vacuum pump, or intake seals, as my Spark plugs and left cam sensors were just recently done.
My belt is new.
I've never heard a PVC system make any noise even remotely close to that, but clearly something is causing it. I'd block off the PVC hose to the intake and see if it goes away, then you'd know for sure. You can pop the hose off near the throttle body. I have a pix of it somewhere because I popped that line off to add a catch can because my intake was dripping wet with oil. Apparently that's normal, so something else to think about
Actually was found by a friend, completely by accident, unplugged it to get to another part and just happened to catch it in the corner of his eye. It actually looked like it was nicked by a sharp blade not split due to age or heat cycles, probably why it was able to make the high pitched chipping sound.
Problem solved,
In the comments of the vid a guy says: "The noise you're hearing is air passing through the front crank seal due to high vacuum. Pop the diaphragm cover off the vent valve, remove the diaphragm and spring, cannibalize the same parts off a new valve assembly and reassemble."
I dunno, guess I have to take his word for it since I never opened that thing up. I'm also assuming he's taking about where the air for the PCV enters the valve cover? From what I remember it's a cast Alum piece that looks like part of the valve cover? To me "crank seal" is something else. No, not a condom, but the parachute oil seal on the crankshaft, which would not make any sound. I figured there was simply some baffles under that cover to keep oil from exiting, but clearly it's more complex.
So that mystery crack/split/cut in your tube; we're talking about the hard plastic ~1/2" OD tube that connects between the eng and brake booster? I'm trying to figure how that leak could make noise? If it's the "front crank seal" then a leak on that tube would mean less air is passing through said seal so it should not make noise. Uggg...
Well, glad you found it so quick or you'd likely be chasing that ghost for a while.
We are not talking about a hard plastic tube, we are talking about a 3/16" soft rubber vacuum line attached to the back of the intake plenum above the vacuum pump that somehow got a small cut just big enough to produce a noise akin to letting air very slowly escape a balloon making a high pitched squeal. Again, sorry if I led you down the wrong path.
Where did the front crank seal inter the conversation? You lost me, there.
The noise was highly localized exactly where I had previously stated, not much else there but a stethoscope helped pinpoint the location, once the line in question was moved for better observation as the sound was from a cut on the bottom of line so sound bounced off top of valve cover, noise changed pitch and was easy to see where it originated.
I spent my life chasing noises in customers cars, if a fairly accurate description and when is given, I can find it. Very rare that I've not.
I know I'm getting old, and my communication skills have faded, I thought I gave a clear description. So my apologies for any misunderstanding.
