Sponsored by: CARiD
Replace glove box latch on 2014 E350
Old Aug 24, 2023 | 07:04 AM
fganter's Avatar
E350
The glove box latch on my E350 came out. Apparently, the two plastic hinges on the latch broke, while the related pin on the glove box is still intact.
latch with broken hinge
hinge pin still intact on glove box
I see that I can buy a latch replacement.
Am I able to remove the pin in the glove box, so that I can install the new latch? I've seen other posts that suggest the entire glove box needs to be replaced. However, this seems odd.
If I am able to remove the pin, does anyone know how to position the following piece, which I'm assuming is a spring for the latch?
latch spring?
FWIW I did see this post. However, it seems pretty kludgy.
Thanks for any help.
Old Aug 27, 2023 | 02:25 PM
fganter's Avatar
E350
bump
Old Aug 27, 2023 | 03:58 PM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
Sorry no one has helped, mine have not broken so I don't know, I will go out and take a picture of my latch pulled to release, maybe that will show something.
Old Aug 27, 2023 | 05:38 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
same here..., I duno that latch
I can remove the box but not its latch
Old Oct 18, 2023 | 12:01 PM
kwoehler1's Avatar
2014 GL 350
I just replaced the latch on my GF's 14 GL350. It's not really meant to be replaced so I did a write up of how I did it. It's a little different, but I think you could do something similar with yours if you haven't figured it out yet.
https://mbworld.org/forums/gl-class-...placement.html
