Engine Mount replace
Driver side is easy, but for passenger side I had to remove DPF and then it was easy.
Your engine might not have DPF, so check the access.
I have lift with cross member and somewhere I found a point where I could put bottle jack between lift and solid part on the engine.
For passenger side mount, DPF has to go out. I tried special wrenches and it did not work. With DPF removed it is child's play.
Since I removed DPF few times before, with lift it is 20 minutes job for me.
At this point, I could do both MM on lift with slightly above 1 hr.
Even if you have skills, the learning curve doing the job 1st time, usually triple the time.
Do I understand right that you got away on the right side without removing the dpf and just loosen the bolts of steering box?
I'm heading to a same job soon and I want to be prepared.
