Sponsored by: CARiD
Engine oil leak at the back of the heads 2011 v6
Old Nov 28, 2023 | 11:45 PM
zenocchio's Avatar
2011 E350 wagon, 2014 E63S Wagon
I have an oil leak at the back of the heads on my 2011 v6. It looks few plugs from the driver side and a bigger cover in the passenger side. Maybe a crank case vent? Any idea of the parts needed and if there is a guide for it? Thanks!
Old Nov 29, 2023 | 06:55 AM
Bdevil82's Avatar
2011 E350 4Matic Wagon 2002 E430 2004 SL500
This:
https://www.fcpeuro.com/products/mer...kit-oem-515810
Or this:
https://www.fcpeuro.com/products/mer...es-2720100631k
Old Nov 29, 2023 | 10:19 PM
zenocchio's Avatar
thank you!
i ordered the parts from rockauto.
cheers
Old Nov 30, 2023 | 05:32 PM
Raj1471's Avatar
2011 Mercedes E350 4Matic Wagon
Be very careful If you are replacing the oil drip pan...the spherical part that is located in the engine behind the engine crankcase vent valve on the passenger side of the vehicle. It's a left hand thread when removing and bolting it in. Do a YouTube search on replacing this on the M272 motor to get an idea of what this job entails.
Old Nov 30, 2023 | 06:13 PM
zenocchio's Avatar
why is that part needed to be replaced? I only ordered the cover plate, as I have oil seepage from the gaskets
Old Nov 30, 2023 | 06:32 PM
Raj1471's Avatar
When I worked on my vehicle, I decided to replace the oil drip pan with the outside cover being that the oil drip pan can be gunked up with oil. There are vent holes in the oil drip pan and these could be clogged from old oil. I wanted to replace all of it because I didn't want to have to replace at a later date. Ultimately your choice and your dime.
Old Dec 1, 2023 | 02:53 AM
ChrisHimself's Avatar
SPONSOR
11 E550, 16 AMG GTS, 13 S550
plastic vent valve/cam plugs
__________________
Alpha European Autotech
Purchase Amsoil at 25% off from me
Chris Tran, Retired Alpha European Autotech Owner
Amsoil Independent Dealer #7236674
Old Dec 14, 2023 | 10:04 PM
zenocchio's Avatar
I replaced the two small cam plugs. the kit came with a third big one but I wasn't able to locate it. i suspect that it is needed in some configurations but not on the e class?
Old Dec 14, 2023 | 11:10 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
https://mbworld.org/forums/e-class-w...ml#post5524800
Old Dec 15, 2023 | 11:28 AM
zenocchio's Avatar
i cannot seem to locate the location for the big plug on my engine. On the driver side valve cover there is a metal plate, I think some how that replaces the plastic plug?
Old Dec 15, 2023 | 11:41 AM
JCM_MB's Avatar
Old Dec 15, 2023 | 12:25 PM
zenocchio's Avatar
Originally Posted by juanmor40
that confirms that the e class has a metal cover in the location of the big plastic plug
Old Dec 15, 2023 | 01:17 PM
JCM_MB's Avatar
Not certain. The 2008 E350 with the same engine has the 3 plugs, and the C and GLK350 with the same engine have 3 plugs. Not certain if for the last generation of M272 on the W212 they upgraded the larger cap. I do not have a sample car to look at.
I would be surprised if they did.
Old Dec 15, 2023 | 03:54 PM
zenocchio's Avatar
here some pics of my engine. Hard to see but it shows the small plastic plug and big metal plate il lieu of the big plastic plug
Old Dec 15, 2023 | 04:05 PM
JCM_MB's Avatar
Interesting your engine has a pump at the back of that camshaft. I did not know they added that on the W212. The W211 does not have it.
Old Dec 15, 2023 | 06:27 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
no pump... no problem
the vacuum pump is at the back of bank 2 intake camshaft.
You can be happy not to have this pump. A simple NA engine without this pump has no check valve maintenance.
