Sponsored by: CARiD
is it NORMAL Engine sound?
Old Nov 30, 2023 | 06:18 AM
mymercy212's Avatar
w212
i have 2010 E-Class(W212) M272.920(3000cc)
i change engine oil every 6 month shell helix ultra 5w-40, MANN 718/5X Fleece filter
is my engine sound Normal ? i'd like to know
Old Nov 30, 2023 | 06:35 AM
GreasedFolgore's Avatar
2025 Maserati Grecale Folgore and 2024 Jaguar F-PACE SVR
Sounds like there are a bunch of little explosions happening inside there! I'd get that looked at immediately by someone with the proper credentials to feed you a BS story and charge you a bunch of money for doing absolutely nothing.
Old Nov 30, 2023 | 10:55 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
SCAN THIS BEAST ....
It does sound healthy, the idle is smooth, that says a lot
Yet sound alone is not the best way to diagnose a modern workhorse...
You need to connect a scanner such as Launch CReader Elite to read all modules faults.
This will empower your ownership to reach a whole new level of armchair mechanics
Old Nov 30, 2023 | 05:22 PM
Raj1471's Avatar
2011 Mercedes E350 4Matic Wagon
Old Dec 15, 2023 | 11:48 AM
W205C43PFL's Avatar
Originally Posted by Raj1471
Ah, the good old ICE, internal combustion engine. What will I do without you : )
Old Dec 24, 2023 | 01:24 AM
d0nedeal's Avatar
2014 Mercedes Benz E350 4Matic
Engine Error code
Guys mine have this error code
what could it be?
Old Dec 24, 2023 | 06:00 PM
TERMINAL STAGE
what could it be?
WORNED OUT ENG...
lots of parts + lots of labor.
This fault means your engine is asking for a new camshaft with other 3 not far away.
Given enough rattling, the sensor wheel has shifted. That is driving the ECU timings off the charts...
This is a big job:
Remove highpressure rail
remove injectors
remove valve cover
replace new camshaft
replace new VVT Phaser
replace new HPFP + Roller
replace new tensioners
Set engine exact timings
Applicable to 1x or 4x camshafts.
Old Dec 24, 2023 | 08:19 PM
d0nedeal's Avatar
Originally Posted by CaliBenzDriver;[url=tel:8897575
8897575[/url]]WORNED OUT ENG...
This is a big job:
remove injectors
remove valve cover
uhoh good to know! Sheesh! Thank you for the reply 🙏
Old Dec 24, 2023 | 08:30 PM
sayonara
if your transmission last service was a longtime ago, this job may not be worth spending a dime on -
Let somebody else enjoy this tic-tic - Even dealers say VVT rattles are no problem... Why can't you then!
Old Dec 25, 2023 | 12:33 AM
d0nedeal's Avatar
Originally Posted by d0nedeal;[url=tel:8897624
8897624[/url]]uhoh good to know! Sheesh! Thank you for the reply 🙏
I don’t have check engine or that much of a ticking but I do have oil residue on the sensor, idk if cleaning or replacing would make it go away, jus had the car for two month, got it from auction and they never mentioned it.
Old Dec 25, 2023 | 01:01 AM
AUCTION BUY: serviceable or junkyard grade....
what's your budget to keep this car on the road?
It doesn't have to be perfect to keep moving forward on oil alone....
what sort of mileage....
Old Dec 25, 2023 | 07:10 PM
d0nedeal's Avatar
Originally Posted by CaliBenzDriver;[url=tel:8897696
8897696[/url]]what's your budget to keep this car on the road?
it has 150,000
and idk 2-3K
Old Dec 25, 2023 | 09:19 PM
it has 150,000
and idk 2-3K
Looking at you scanner screen, I see you don't have an active CEL because the fault is in PENDING status - The ECU is still debating...
If you don't have rattling perhaps it's the balance shaft messing up timings. There is a kit for that...
balance shaft repair kit
Old Dec 26, 2023 | 12:09 AM
d0nedeal's Avatar
Originally Posted by CaliBenzDriver;[url=tel:8897945
8897945[/url]]Looking at you scanner screen, I see you don't have an active CEL because the fault is in PENDING status - The ECU is still debating...
looks tensed lol, might start working on that over the weekend, wish me luck 🤞
Old Dec 26, 2023 | 01:25 AM
No point in rushing to fix anything without a solid diagnosis... you're paying for it.
Use your scanner to read live timings.
Old Mar 11, 2024 | 01:07 PM
Ferreiraclovis's Avatar
e55 amg
I have a problem with the M113 of the E55 amg year 2000, there is a lot of white smoke coming out of the exhaust with oil residue, the cylinder capacity is mostly at 170psi, I have already changed the valve seals and the same problem remains, where else can it be?
Old Mar 11, 2024 | 08:57 PM
headgasket...
A lot of white smoke sounds like.... one of your two headgaskets is letting coolant in one of the cylinders.
-- What is the coolant level like: low??
-- Any chance the engine heads recently got overheated and warped.
-- Perhaps one of the long aluminum head bolts let go..?
-- I dont think it is heat exchanger but check the engine oil dipstick for oil level and appearance.
... I hope I'm wrong
Old Mar 12, 2024 | 06:58 AM
e55 amg
[QUOTE=CaliBenzDriver;8937791]Muita fumaça branca parece... uma de suas duas juntas de cabeçote está deixando líquido refrigerante entrar em um dos cilindros.
-- Como é o nível do líquido refrigerante: baixo??
- Há alguma chance de os cabeçotes do motor terem superaquecido e deformado recentemente.
-- Talvez um dos longos parafusos de cabeça de alumínio tenha se soltado..?
- Não creio que seja um trocador de calor, mas verifique a vareta do óleo do motor quanto ao nível e aparência do óleo.
... Espero estar errado :louco:[/QUOTEThe water has no oil and also does not get low
I will analyze these or other items
thanks
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABQAAAAUCAQAAAA ngNWGAAAA/0lEQVR4AYXNMSiEcRyA4cfmGHQbCZIipkuxnJgMStlMNmeyD2d wmc8+sZgxYJd9ErIZFHUyYYD7fkr6l4/rnvmtl7+KitrqV/fq2Y5eLY3Z9S48eRLe7BmVZ9qhTLhQ0algzZWQOVKSsCF8OjAn wbxDTWFDUhPK/jMr1H6HE/IqRky2DyvCefuwItwZzodVoYRiLqMkVCXrwpJ9twZ+sgfDYEFY l8wIWxZ9uFf7zkallxlJh4YrLGsKjZRx7VGHhLqwgFUN45DGdb 8MeXGpgB4ABZdeDcpZEY51A+hyLKz4S1W4MQWm3AibWtgWmk6d yISa1pSdyWTOlLXVp0+eL9D/ZPfBTNanAAAAAElFTkSuQmCC[/img]
Old Mar 12, 2024 | 06:20 PM
caro malo...
[QUOTE=Ferreiraclovis;8938368]
thanks
Please use English...
At any rate BIG WHITE SMOKE:
means catastrophic engine failure.
Your safest chance is NOT TO DRIVE.
