Sponsored by: CARiD
Wireless Apple CarPlay
Old Dec 14, 2023 | 01:30 PM
Sparkling's Avatar
2019 GLE 43 AMG Coupe
Hi all,
I am trying to find a plug and play wireless CarPlay to connect my iPhone to my 2014 Mercedes Benz E350. Not looking for the types were they should be installed, just the plug and play and came across some that can be plugged into the USB and just work. My car has one USB plug which I have connected my flash drive to listen to music. There is another plug that already has a media converter plugged into it and that came with the car. Should I buy some type of USB extender so I can plug in both the flash drive and the wireless carplay or I should find some other cable that works with the media connector? This is the item I was interested in purchasing:
Amazon Amazon
Thank you in advance
Old Dec 16, 2023 | 03:44 PM
KlausPA's Avatar
E350 Wagon
Do you have Carplay already installed, and you are looking to make it wireless?
Old Dec 17, 2023 | 12:05 PM
Sparkling's Avatar
i don't believe so, I checked the options on the the display but it doesn't seem to have that option
Old Dec 17, 2023 | 01:24 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
I'm an Android not Apple, but I can't imagine that a device doesn't exist like the Motorola MA1
This turns my truck's wired Android Auto into wireless and works flawlessly and invisibly.
Old Dec 17, 2023 | 01:41 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
there was no carplay or android auto support at all on a 2014. the only way to add it is to get a complete system that sits between the COMAND processor and the screen. In 2016, Mercedes upgraded the COMAND to NTG5.1 which was the new version that the W213 used, *those* units can be flash upgraded and coded to enable wired carplay/android auto.
Old Dec 17, 2023 | 02:39 PM
Sparkling's Avatar
Got it, thank you,
Old Dec 18, 2023 | 04:00 AM
Carlinklife's Avatar
Former Vendor of MBWorld
Regarding the upgrade of w212carplay. You can browse this thread.
https://mbworld.org/forums/e-class-w...play-w212.html
Old Dec 18, 2023 | 02:13 PM
Sparkling's Avatar
Thank you so much, I will check my dashboard compartment and see if mine has that Becker slot. I saw a cable which came with my car, already connected to a slot in my glove compartment (across from where the flash drive USB plug goes). I attempted to disconnect that cable, one end looks like this Becker slot. could that be it?
Old Dec 18, 2023 | 02:27 PM
afaik, that Becker module slot in the glovebox was only on world market models, not US models.
Old Dec 18, 2023 | 02:40 PM
Sparkling's Avatar
Oh thank you, so my car most likely doesn't have it. There is a similar looking outlet in the armrest compartment (across from where we plug in the USB flash drive to play music), it looks like a media cable, not sure if we can use that to hook a wireless car play...
Old Dec 18, 2023 | 02:46 PM
my 2016 E350 has two USB ports in the armrest, which can be used for media, and for charging, but not for phone integration, UNLESS you have the NTG5.1 system AND have hacked it for CarPlay/Android, then the USB 2 port is for the phone.
Old Dec 19, 2023 | 03:24 PM
Sparkling's Avatar
My car only has one USB port and the other one (in the same compartment), is not a USB port, it has a media cable looking thing attached to it that came with the car. Wasn't sure if that is something I can use to attach the wireless Car Play to
Old Dec 19, 2023 | 04:38 PM
could you post a picture of this 'media cable looking thing' ? Not quite sure what a 'media cable' is... And looking at the 2014 E sedan/wagon brochure, https://www.auto-brochures.com/makes...Class_2014.pdf not sure I see anything suggesting what it might be.
Old Dec 19, 2023 | 04:43 PM
This is the dual USB port I've seen under every w212 center armrest that I've looked at...
Old Dec 19, 2023 | 04:48 PM
ok, do you have this MMI connector? you can get a cable for that that lets you use that for analog aux input headphone plug style, or as another USB port for a USB stick with music. Some vendors make a bluetooth dongle that plugs into those MMI connectors
Old Dec 20, 2023 | 08:44 AM
Sparkling's Avatar
Yes, this looks like the port I was talking about, it's inside the compartment where the USB port is located (across from it), came with a cable. I found these pictures online (below) to show you what mine looks like, Will I be able to use this port to attach some type of carplay device?
Old Dec 20, 2023 | 11:23 AM
No, that will only support a USB stick with music files. A different cable supports aux analog audio in via a headphone plug. Your car predates Carplay support by 2 years.
Old Dec 20, 2023 | 02:02 PM
Sparkling's Avatar
Ah, so I am out of luck. here are all the cables and ports (aside from the USB)
And this last picture is from my glove compartment, I see an empty rectangle spot but no port
