Sponsored by: CARiD
Assistance Graphic
Old Oct 17, 2023 | 09:41 AM
Rickman30's Avatar
Veteran: Navy
2014 Mercedes-Benz E350
Assistance Graphic
My Assistance Graphic does nothing, Everything is "Enabled" but it still says off at the top. The build sheet shows I have 258 Collis.Warn. Sys. w/Active Brake Interv. FCW Stop, 476 Automatic Lane Recognition. No Histrionic. Any clues?
At top it says "off" no matter if Distance Warning is enabled or disabled, no codes in Xentry or Thinktool. Thinktool actuation tests, distance does show up for Distance Warning if I am standing in front of car and does change if I move closer or farther away.
Old Oct 17, 2023 | 12:08 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
SGR is ghosted 🙄
That is really odd!! As you state it's not just the display graphic - The whole distance sensitivity is kaput!!
No distance warning, no OBD faults while related feature options are enabled
What happens when you initiate Distronic while driving with the steering wheel control knob ??
How many windshield camera do you have?
What style front radar is installed?
Any interesting data inside SGR and CGW Modules that codes these features ??
You maybe left with no other recourse other than a simple Reboot to untangle the networked logic.
Old Oct 17, 2023 | 12:14 PM
Rickman30's Avatar
Veteran: Navy
According to build sheet, I don't have Distrionic or Distrionic plus, just the Distance warning and lane assist, Only one camera in front, no center radar, just two sensors each side of front bumper.
Might need to get the Benzninja to sort it out. After all, being a member...
Old Oct 17, 2023 | 12:29 PM
Originally Posted by Rickman30
According to build sheet, I don't have Histrionic or Histrionic plus, just the Distance warning and lane assist, Only one camera in front, no center radar, just two sensors each side of front bumper.
Okay, that starting to make sense:
  • No Distronic cruise control installed.
  • Single mono camera.
Then the camera must have something odd going on with it. Can you query the module or is it ghosted off the CAN, unable to report?
Old Oct 17, 2023 | 12:36 PM
Rickman30's Avatar
Veteran: Navy
No, I was able to read data off of it, but it does make more sense since my rain/light sensor is throwing a code for a short to ground. I have yet to begin diagnosing it since the wipers and lights still seem to work okay.
Old Oct 17, 2023 | 12:39 PM
Rickman30's Avatar
Veteran: Navy
I'll plug up Xentry this evening and see where it leads me. I'll look to see if it is Ghosted as well. Sometimes Thinktool shows modules and codes where Xentry see everything okay.
Old Oct 17, 2023 | 12:42 PM
quick repair
There you go!!
Your solderless rain sensor is creating a data bottleneck. Camera is able to talk but slow-speed only through traffic jam.
This highlights partner modules are clueless to this
I am going to bet if you fix the rain sensor, playtime will resume. ✌️
luckily its easy to fix - Look in my signature links: free for the braves!
Old Oct 17, 2023 | 12:50 PM
Rickman30's Avatar
Veteran: Navy
I'm betting you're right. Makes sense now.
Old Oct 17, 2023 | 01:18 PM
Rickman30's Avatar
Veteran: Navy
There you go!!
I'm only finding a partial list, I thought I remember more being on the list, I don't see rain sensor on this one.
Old Oct 17, 2023 | 02:03 PM
Let me go fishing for that quick-fixing...
Here you go - Choices are 30mn fix or get it replaced.
This is entry level electronic basic soldering.
Alternative option is new module with SCN coding.
Pick your poison!
Solderless Easter Eggs hidden in plain sight
The way I see this module is a perfect practice before fixing the worthy EIS CAN gateway.
Old Oct 17, 2023 | 03:59 PM
Rickman30's Avatar
Veteran: Navy
Pick your poison!
Thank you, Cali.
Should be easy enough, been soldering since 1979, I got a well used Hakko with some new tips to try out, a bent tip I wanted to give a shot at. I normally work on Tube Guitar amps and audio equipment. So I'm use to rework of a sort.
Old Oct 17, 2023 | 04:13 PM
nice + easy = painless ...
See that's what I mean, choice is a no brainer here.
3 quick solders and you are done - No aggravations: bang!
As far as other soldering opportunities nearby, the OCP and rearview mirror are built reliably. I don't know what's inside the sealed forward camera module.
Old Oct 17, 2023 | 04:16 PM
Rickman30's Avatar
Veteran: Navy
I'm all about, "No parts required".
Thanks again Cali, you da man.
Old Oct 17, 2023 | 04:51 PM
team focus
I am glad I can help organize chaos with simplicity to meet your needs - I am only one of da men, many-many great ppl around here...
You know, with a collective focus we are able to cancel complex struggle to make these cars tic better than factory.
Old Oct 18, 2023 | 04:45 PM
Rickman30's Avatar
Veteran: Navy
Well, reworked the three pins in the Rain/Light sensor, reinstalled, cleared codes, and no joy, hard fault remains, internally grounded, so the main chip has taken a dump on it. All components looked good, I did not apply power to see if chip was good as I'd hoped it was the solder less connections.
I acquire a new unit and get Benzninja to do the coding on it.
I also noticed, Xentry did not show any other codes save the Backup camera, which still works fine, but Thinktools shows M-Brace codes says internal ground and algorithm fault. I'm wondering if rain sensor is disrupting all sensors there? I also wonder why Xentry doesn't show them as well.
Also, appears all modules visual in topology. Unless old eyes and dyslexia are fooling me.
Anyway, thanks to all who helped, much appreciated.
Old Oct 18, 2023 | 05:10 PM
progress...
Don't throw in the towel just yet!
You have a fault pointing to GND issue, right?
Go clean the poor footwell GND Posts. Either you pinpoint which W# it is or simply clean both sides for good measures.
Do disconnect BOTH BATTS while cleaning GND
(Driver side feeds SAM + ECU!)
Can you see inside you OCP if you read a bogus temperature.
M-Brace complaining is from the OCP Buttons getting disconnected.... no problem, reset!
Ultimately this may or may not fix your issue - It may be an issue with CAN/LIN involved around the OCP & Camera.
I still have the wonky OCP Temp but everything else ok with Stereo camera, DistronicPlus, Rain/light sensor.
Old Oct 18, 2023 | 05:52 PM
DFWdude's Avatar
2016 E350 Sport
My car has the same features noted as yours, and the display looks the same. I believe without Distronic that this is the display you get as default. Nothing else. I.e., it's a placeholder graphic for Distronic in all cars (mine's a 2016), but doesn't display "interactive information" without Distronic.
Old Oct 18, 2023 | 06:02 PM
no radar sensor
no distance measured
no display scale
off as in disabled??
Strange thing is the "OFF" - Any way to toggle ON through menu settings?
Old Oct 18, 2023 | 06:07 PM
Rickman30's Avatar
Veteran: Navy
It does say grounded internally in the code description. However, I will certainly check both grounds.
Old Oct 18, 2023 | 06:29 PM
FAULT CITERIA TIPS
This is a cryptic message misleading at best. For me this means an issue with power supply - Take it with a grain o' salt.
There's an oddity in this circuit that bites a lot of ppl most unknowingly. I think I am one of those with busted OCP Temp
Can you read the code setting criteria in your Xentry > that would provide us with advanced tips.
Old Oct 18, 2023 | 07:56 PM
Rickman30's Avatar
Veteran: Navy
Code definitions usually are cryptic, code setting conditions, TSBs, and redrawn wire diagrams, are a bigger help.
I hope Xentry does give code criteria, although I had to cut my session short, company. I should be able to give it a little investigative time tomorrow.
I may search for info online tonight too. I am still learning Xentry too.
Old Oct 23, 2023 | 07:32 PM
Rickman30's Avatar
Veteran: Navy
no radar sensor
no display scale
I tried toggling everything off. didn't change. Benzninja said fix rain sensor first. I did that, no change on graphic tho.
However, interesting discovery. In the data on my ThinkTool Pro, the distance and side variation readings never change, everything stays 2.14 yards away and -.13 from center, despite moving around in front of car in open area. So I drove car and observed, no cars in front of me and reading never changes, I tried resetting and these remain the same. I will see what the Benzninja makes of this tomorrow.
I think I see a bumper removal in my future. That's okay, I have a new lower grill that has been sitting on the shelf to install. Would be nice to add Distrionic Plus to the car while in there.
This so exciting...
Old Oct 23, 2023 | 08:17 PM
nothing in bumper... ?
Would be nice to add DistronicPlus to the car while in there.
This so exciting...
I though everything was computed by the windshield camera and no bumper radars were in use in your car, right? Windshield camera is a solderless module, not friendly sealed 🙄
Distronic+ is fantastic but requires special compatibility from ESP, EPS, MFK, 3 Radars and a controller module (forget about it!)
++++ Nothing to loose: TAP-TAP TEST
Be curious do some tap-tap on the back of camera unplug/replug connector to exercise loose pins a little..
Old Oct 23, 2023 | 08:47 PM
Rickman30's Avatar
Veteran: Navy
I thought so too, but non Distronic models have sensors in the bumper much like the rear sensors you are required to remove bumper and clean off periodically. According to my owners manual, on non-Distronic models, the windshield camera is responsible for lane recognition and the "Coffee Break" nanny. The bumper sensors for "Collision Assistance". But "tap tap test" on bumper sensors and camera while watching the distance readings might be interesting. At the least a reasonable ave.
Remember my Backup camera fault codes. Today while screwing with the front distance readings, the ESP, ESP off, and ABS, lights flashed simultaneously on and off once, and the backup screen flashed blank and back on. Either the scan tool did this, as I'd never seen it before, or having the scan tool connected caused the fault to show in a different way. Weird man...
I haven't done the cabin grounds yet, but am anxious to look at the backup cam module. I bet them pesky press fit pins lurk in there as well.
Like you said, soldering all these potential fault areas should help keep the electrical gremlins at bay, plus all the neat little preventative maintenance areas S-Prihadi shares. A lot of work ahead.
Old Oct 23, 2023 | 09:03 PM
2 radar + 1 Cam.
All right, so you do have two side close range radars hidden inside front bumper + windshield camera.
The bumper radars are known to soak rain thtough connectors and the bumper harness connector needs inspection for water damage as well.
You should be able to go read distances inside each radar module - If none are available the passenger side harness connector may be directly at play (same game in rear bumper).
I don't think rear cam is involved in the front watchdog.
Presumably when any of your front radars or camera detects a danger they call on the ESP to apply the wheel brakes automatically - That is a great feature!
My car slammed the brakes autonomously in traffic couple days ago when the car afront of me suddenly stopped. These has saved me from troubles many times because I drive more relaxed knowing my ride's abilities.
I'm pretty sure we'll get yours working again.
++++ harness access:
passenger plastic wheel well cover.
