Hi Folks
I would like to add some Dynamic LED DRL and indicator strips to my E350. I need to connect them up to the Delphi Plug as shown in picture, but I cannot find a schematic or picture of the pinouts anywhere on the web.
Is anybody able to advise or attach a diagram or picture of the pinouts please? I found that E5 for example is the left indicator. Thanks in advance.
Hi CaliBenzDriver
there is nothing in there aside from the standard setup for the 2012 model.
I have the Dynamic LED strips which connect to right and left, I managed to figure out how to get it installed, BUT i need the pinouts of the Delphi plug which is the 14 pin one.
I have actually just arrived home from Santa Clara, home being New Zealand.
cheers
J
01. Show a photo of what you meant by : Dynamic LED DRL and indicator strips
The definition of Dynamic headlight (complete unit ) is a code 640/641/642 Dynamic LED,which many call them ILS and this is the highest grade headlight if for a W212 era.
Hence Cali was asking his questions too ....
Also go and use a VIN decoder to identify what headlight code is yours. You can't simply say a 2012 model and that is it. You will be having migrain when u see the WIS for types of headlight W212 uses.
There are plenty types and depending on region too and their wiring is a nightmare to use when you do not know exact model/code of the headlight
