Sponsored by: CARiD
left side DRL problem
Old Dec 27, 2023 | 06:23 PM
vr1983's Avatar
W212 CDI
Hi guys,
I need help if someone had the same problem.
A few days ago my left DRL stopped working and I got message on screen, so I got new one from ebay (L hockey type) and installed it
and nothing...no luck
tried checking fuses in engine compartment and disconnecting battery, still no luck
Any ideas?
Old Dec 27, 2023 | 07:47 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Your new headlight most likely needs to be coded to begining operating. HL programming data is held by the HL control module.
Old Dec 29, 2023 | 08:18 AM
vr1983's Avatar
W212 CDI
probably because short circuit happened and module needs to be decoded.
Now I need to find someone with MB scanner
Old Dec 29, 2023 | 08:40 AM
antboii's Avatar
2013 w204 c250 coupe & 2001 Dodge Ram 2500 24v Cummins
Exclamation
Originally Posted by vr1983
Hi guys,
Any ideas?
Hey man, is the L style DRL LED?
If so, you might just have to flip the chip that plugs into the original bulb socket.
IF that doesn't work, check fuses as you did, follow the wiring, check grounds etc..
Ant
Old Dec 29, 2023 | 09:24 AM
vr1983's Avatar
W212 CDI
Ant
yes, L style.
some says that there is no fuse for DRL lights
Old Dec 29, 2023 | 10:57 AM
antboii's Avatar
yes, L style.
Got it.
Try flipping the plug for the LED's. could just be that the positive and negatives are flipped.
Old Dec 29, 2023 | 11:11 AM
vr1983's Avatar
W212 CDI
Got it.
plug goes only one way, impossible to reverse it.
