Sponsored by: CARiD
Knocking Sound 2014 E350 M276
Old Feb 23, 2024 | 01:19 AM
S-Prihadi's Avatar
See if your s-park plug tool lacks the top side gripper, some uses rubber insert as gripper to prevent spark plug from not being centered.
Below is a simple but good video , where the ceramic may crack
Old Apr 14, 2024 | 06:13 AM
E350-FR's Avatar
W212 E350
Hi everyone, my W212 E350 does exactly the same sound. This model was not sold in France (it is a German import) so the mechanics here are not use to the M276 and they just suggested me to replace the motor (because they suspect a rod issue)....
@Geep 250GD @2015-E350-Wagon do you confirm that after the spark(s) replacement the knocking sound is gone? (it should be cyl #2 for me as I had a few sporadic misfires here in the past)
Thanks!
Old Apr 14, 2024 | 08:53 AM
2015-E350-Wagon's Avatar
W212
Yes. In my case, replacing spark plugs solved the sound / issue (as described). I’ve run the wagon another 2-3k miles since. No issue
Old Apr 14, 2024 | 08:59 AM
E350-FR's Avatar
W212 E350
Thanks for the feedback ! At least, given the price of a set of spark plugs against a brand new engine, it worth trying
Old Apr 27, 2024 | 09:57 AM
E350-FR's Avatar
W212 E350
The issue was the spark plugs (two in my case, cyl #2 and #3) !
Engine sound before:
Engine sound after:
And here is one of the plug in question:
I suspect that the torque (and so, the index/orientation) was not respected by the previous mechanics...
Thanks again for this thread, it saved my engine (!)
Old Apr 27, 2024 | 01:43 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
OMG!
Thank you for these great video.
That failed sparkplug is really something to see it slide up/down!!!
Overheated ignition coils and boots are known to require replacement to prevent misfirings.
Old Apr 29, 2024 | 11:13 AM
  #32
E350-FR's Avatar
W212 E350
In addition, I found that (kinda scary) recommandation from Mercedes about SP indexing on direct injection gas engines, including m276...
File Type: pdf
Old Jul 25, 2025 | 11:48 AM
  #33
Thomas Gamst's Avatar
Same fix!
I experienced the exact same issue with the knocking sound and the problem also turned out to be two broken spark plugs.
Mercedes listened to it and suspected a major engine problem, with anticipated need to take the engine out for proper diagnosis. I showed them this post and they checked the plugs and found the issue.
Thanks for sharing in this forum - it most likely saved me thousands of EUR and a lot of time 🙏
PS. My car is also an E350 cabrio from 2014. Only 42000 km and allways maintained at Mercedes. So, a damaged engine sounded unlikely.
https://youtube.com/shorts/I_B_sXU4yaY
Engine sound after:
https://youtube.com/shorts/3WzBw1RlF1k
https://youtube.com/shorts/TQv8leWjQPU
I suspect that the torque (and so, the iindex/orientation) was not respected by the previous mechanics...
Old Jul 25, 2025 | 01:38 PM
  #34
MB PLUGS FAILURE
Thank you for confirming there seem to be an epidemic of junk defective MB sparkplug that fall apart early on.
Extreme heatsoak likely involved with thermal shock.
Old Feb 12, 2026 | 11:50 AM
  #35
mkosover's Avatar
2012 MB R350
Thank you for posting your findings. Just wanted to chime in, in 2023 I replaced plugs in my 2012 MB R350 with 6 Bosch ZR6SII3320 plugs.
I heard a distinctive knock on passenger side. This post gave me a good direction to follow, and sure enough, when I removed the passenger side plugs, I found cylinder 1 plug failed where the inner portion would move resulting in no proper gap.
The other plugs from cylinders 2 and 3 had a wide brown band on the ceramic portion, indicating a blow by gasses making it through the plug.
Interestingly enough, the car ran fine otherwise and at least there was no a visual indication of misfire, I did not go into scanner to confirm it either way.
The only other thing I want to add, is that I ran into this situation once before. I was working on 2017 Jetta and I bought Bosch plugs. Over short amount of time, 2 of those plugs failed in the exact same manner, except car
was misfiring badly and it was pretty obvious what the issue was. I replaced Bosch plugs with NGK equivalent and the issue never returned.
Unfortunately, there is no NGK/Denso approved replacement for the MB that I found, so I replaced all 3 passenger side plugs with another set of Bosch.
All 3 failed plugs hail back to 2022-2023 manufacturing, so hoping that the defect was addressed since.
Old Feb 12, 2026 | 12:46 PM
  #36
spark plugs work
How soon did you see these Bosch plug fail ?
After 50kMi or way prematurely defective like 20kMi ??
-- Now if this is your engine, you should really replace Cyl.4+5+6 to run both banks nearly identical.
-- Also replace the plastic BOOTS that have the carbon-stack resistors built-in.
There must be a perfect NGK/Denso upgrade!!
Top Japanese brands license the Bosch 3.5L-V6 engines design they "make in Japan" with Swiss precision.
flat top design
flat top design
Flat-tops used to connect NGK requires:
  1. the matching flat boots connections
  2. the correct electrode temperature
  3. the right physical dimensions
What's the right cross reference part No??
Old Feb 12, 2026 | 04:55 PM
  #37
mkosover's Avatar
2012 MB R350
The plugs had 25754 miles when I replaced plugs 1-3. Plug #1 likely failed earlier, but difficult to answer. Bottom line, way premature failure, and not just a worn out plug, but a complete failure of the design.
If you watch any of the posted video's in this thread, my failure was identical, therefore knocking noise that I heard coming from head #1.
I don't disagree with your suggestion in regards to replacing plugs 4-6 on driver side head, but will leave it alone for now.
I looked far and wide, but I am not able to cross reference NGK/Denso plugs.
I looked at RockAuto and FCPEuro, and both show Bosch/MB plug. Rock also showed Champion plugs which I am definitely not using here.
Going through Denso and NGK catalogs shows no equivalent plugs.
Napa/autozone does show an NGK plug, but I can not find any supporting documentation that its in fact compatible.
Car in question is 2012 MB R350 3.5L gasoline engine - M276
