Abnormal Coolant Fan Behavior in Mercedes-Benz E300 (2014)
E300 / 2014
Hi
It appears there is an issue with the coolant fan in the car ( E300/2014). Specifically, the fan operate ( run on high, It sounded like a jet engine.) when the car is stationary (parked) It doesn't matter whether the air conditioner is on or off , and when I shut off the car, the fan turn off immediately, despite the absence of any indication on the dashboard suggesting an increase in engine temperature ( 90 to 95 C from the Instrument cluster) or a fault error or any effect on the car performance. Fan is working normally when driving ( no issue at all ) .
Additionally, after conducting a diagnostic scan, there are no reported faults or error codes ( I have reset the Fan system but still the issue is there) , and there is no observable leakage of coolant.
The car continues to function properly despite this anomaly. The Fan is new ( almost 5 months )
Update on 28.1.2024
I have replaced the water pump with a new one ( as the I have notice the coolant degree reach 106C when the car not moving (Parking or N) , so I suspect the water pump is not functioning well ( I have not replace it since 2014 , so I thought it is a good time to replace it at once.).
However the same issue still there, when AC is off no problem at all , with AC is On the FAN start running at high speed again.
Update on 31.1.2024
after replacing the water pump few days ago , the problem semes to be resolved as I have not notice any issue with the FAN ( only the first day after replacing , other than than everything is OK)
More update will come.
Update on 28.1.2024
Update on 31.1.2024
Received 3,449 Likes
MY'14 W212 M276 3.5NA @60kMi
supersonic fan..
Your new fan insist on running supersonic without any useful code from your Mercedes.
Use your scanner to read the AAC ref-gas pressure. Your A/C pressure sensor at the bottom of condenser simply got rained on.
Inspect & clean oxidized connections or replace sensor after data failure?
If you like free bonus we can spot you for one.
E300 / 2014
Received 4,449 Likes
NO, but you need to compare its pressure when engine has been COLD ambient temperature....to R134A refrigerant pressure vs temperature chart.
Read here : https://mbworld.org/forums/e-class-w...mum-speed.html
Good luck
Good luck
